1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
Blend Door Fix.
Old 06-07-2009, 05:57 PM
diamonddave242's Avatar
diamonddave242
diamonddave242 is offline
Blend Door Fix.
Does anyone have any idea how to go about fixing the blend door on a 1998 Ranger? Funny thing about this particular part, it costs only about $11 to $15 bucks but in order to fix it, it will cost close to $600 for labor. That's to take the dash out. I know that there was a way to go through the glove box but can't seem to find the instructions. Or if anyone can give me an idea on how to fix it better, please let me know.
Thanks
Old 06-07-2009, 07:35 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
Old 06-07-2009, 10:41 PM
diamonddave242
Thank so much. I was able to find what I need and more.
Old 06-07-2009, 11:18 PM
Rockledge's Avatar
Rockledge
Good luck, let us know how the repair goes.
Old 06-09-2009, 11:42 AM
diamonddave242
Just another question, I saw a quick fix from a site listed in this forum called Heater Treater. Does anyone have any comments on the product listed on their site or has anyone used it? I don't want to spend $130 before hearing some feedback on this. Any help would be greatly appreciated.
Old 06-09-2009, 10:41 PM
Traxxis's Avatar
Traxxis
Traxxis is offline
Haven't heard of it. I did notice however that in the second link that Rockledge posted, one guy said he used it. Might check it out and mayby PM him.
Stan
Old 06-11-2009, 05:21 PM
diamonddave242
All,
I went ahead and ordered the HeaterTreater via Ebay so I will let you know how that works. Also, doing research online, came across some YouTube videos that may be useful.
YouTube - heatertreater
Old 06-22-2009, 10:11 PM
Traxxis's Avatar
Traxxis
Traxxis is offline
Welp, just got done replacing the blend door on my '97. Pain in the butt. Unfortionately, my door was broken at both ends, so I had to cut the bottom of the plenum out and replace the whole door.
Some Super Glue, JB Weld, duct tape, silicone and it should be good to go! (if you think I'm kidding... I'm not).
Stan
Old 06-23-2009, 12:56 AM
diamonddave242
What method did you use?
Old 06-23-2009, 06:53 AM
Traxxis's Avatar
Traxxis
Traxxis is offline
lol... err... the Traxxis method.
I used a utility knife to cut the bottom of the plenum out, removed the door and replaced it with one from my donor truck. The biggest pain was glueing the bottom of the plenum back on.
I can post some pictures if you like.
Stan
BTW: The whole process took no longer than 1.5 hours.
Old 06-23-2009, 11:34 AM
diamonddave242
The kit that I have just says to used metal tape to patch up the hole. I would like to some pics so I can get an idea. Considering what you went through, the process was fairly simply, right?
Old 06-23-2009, 02:33 PM
Traxxis's Avatar
Traxxis
Traxxis is offline
Yeah, I wanted to use metal tape, but I couldn't find any. Trust me, the way I did it resulted in a mess, just on my hands though. So far, it works. I don't know about the long-term reliability, but we'll see.
The hardest part is cutting the whole in the bottom of the plenum. What you need to do is just cut the whole triangle out, don't try to cut just part of the middle out, because the door will not fit. I used a utility knife, which didn't make it any easier. A rotozip would cut it really nice, but the bits are pretty wide, so you would have larger gaps when you put it back in.
Super glue worked pretty well really, but I will put some foil tape on it asap.
Attatched are some pictures that I thought might help you.
The first three are from the donor truck. The angle is a bit funky, but it is looking up from the floor board into the bottom of the cut plenum. The third is a picture of the actuator.
Old 06-23-2009, 02:40 PM
Traxxis's Avatar
Traxxis
Traxxis is offline
The first picture is the finished picture of the replacement. When you are cutting the bottom out, make sure to cut the little round part out too (on the bottom left of the top picture), this is where the bottom hinge of the door rests.
The second picture is the door I took out, you can see that not only was mine broken at the top where the actuator hooks up, but also at the bottom of the hinge. Needless to say, the nail fix would not have worked for me. So... I did the "Traxxis" fix.
Gotta love the AC... my thermometer is showing 102.1*F right now.
STan
Old 06-23-2009, 10:40 PM
diamonddave242
Wow. Yeah, looks as if it will take some patience too. Umm, so cutting it out, I was just going to use a dremmel tool to do that job.
I plan on doing the job this weekend, hopefully the wife will stay out of my way. When she tries to "help", I always end up messing up on the job. I will let you know what the result are and then send pics. Thanks.
Old 06-24-2009, 09:31 AM
Traxxis's Avatar
Traxxis
Traxxis is offline
lol, I hear you.
I will say though, there was one point where I was going to have my wife come out and help. When you go to put the door in the plenum, put the top in first. Problem is, there is nothing holding the door up there while you try to put the cut out piece back in. I suggest a second hand of some kind.
Yes... patience paid off in this project.
Quick Reply: Blend Door Fix.
