Oil change meter reset?
Old 06-03-2009, 08:01 AM
2001gocougs's Avatar
2001gocougs
2001gocougs is offline
I changed the oil in my Expedition with seven quarts of oil and a new filter. I reset the oil change meter but it only went to 85%. Does the 5.4L have an actual sensor that determines oil life or is this a meter based on mileage with a lawyers cushion built in?
Old 06-03-2009, 01:30 PM
berry1234's Avatar
berry1234
berry1234 is offline
No actual sensor, just mileage. Funny, my 07 would display 90% when I reset it. Why not 100%? Early trip to the dealer. I just go by mileage. Every 7500.
Old 06-03-2009, 03:29 PM
mpm32's Avatar
mpm32
mpm32 is offline
Do a search on it, I read here somewhere how to set the different percentages. Also I think that it's in the manual.
Old 06-08-2009, 06:30 AM
chuck s's Avatar
chuck s
chuck s is offline
The oil change interval is 5000 miles for the '07s and 7500 for the '08 and later. Same engine from what I can tell and I doubt Ford started fitting different bearings, etc., at '07 to '08 model year changeover.
"Hey guys, put the new '08 7500 mile bearings in the next engine down the line. No, dummy, not that one one, it's going in the last '07! The next one!"
I change it when the reminder on the dash tells me to at around 5000 miles but don't get twichy if I have to go over that distance. My Hondas chaim to compute oil change interval.
-- Chuck
Old 06-25-2009, 12:38 AM
2001gocougs
I found the way to reset the meter to 100%.
Press the setup button until you reach the oil life reading.
Press Reset button this should take you to 70-85% reading.
Continue pressing reset button and it will count down by 10% each time until it jumps back to 100% oil life.
Old 06-25-2009, 06:14 AM
chuck s's Avatar
chuck s
chuck s is offline
Mine has always reset to 100% with no extra effort. But it's always been at the "Change the Oil" level to start with. Maybe if you're changing the oil more frequently than the settings you have to scroll thru the percentages?
-- Chuck
Rob89
1999 to 2016 Super Duty
01-05-2017 03:13 PM
JHGC
04-29-2015 10:58 AM
Mike E.
06-23-2013 04:16 AM
roadkingfl
6.7L Power Stroke Diesel
03-28-2012 08:12 AM
thinksnow
09-28-2009 10:20 AM
Quick Reply: Oil change meter reset?
