Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
20% off shocks and brake pads
Old 05-29-2009, 04:07 PM
ShockGuys's Avatar
ShockGuys
ShockGuys is offline
If you purchase shocks and brake pads in the same purchase you will receive 20% off. This can be done at Shockwarehouse.com.
Old 06-05-2009, 06:23 PM
86f1504x4Extended's Avatar
86f1504x4Extended
86f1504x4Extended is offline
What is the promo code to use?
Old 06-06-2009, 06:41 AM
spinella's Avatar
spinella
spinella is offline
its ford5.
Old 06-06-2009, 07:14 AM
86f1504x4Extended
That only gives you 5% and not 20%.
Old 06-06-2009, 05:13 PM
spinella's Avatar
spinella
spinella is offline
your right i'm sorry. maybe when you go to check out it applies thre discount?
Old 06-08-2009, 11:07 AM
ShockGuys's Avatar
ShockGuys
If you buy a full set of brake pads and shocks is where the 20% off will apply. You can purchase brake pads from off the shockwarehouse website, simply add to your cart and the promocode should automatically fill into that field.
If you are purchasing just shocks then you would use the forum 5% discount ford5.
If you have any issues call us at 800.245.7469.
Old 06-08-2009, 11:18 AM
ShockGuys's Avatar
ShockGuys
Correction to my first post:
If you purchase shocks and brake pads in the same purchase you will receive 20% off the brake pads. This will show the discount automatically when you go to check out. You can use the 5% form discount toward your shocks. Use promo code Ford5.
Old 06-08-2009, 12:47 PM
86f1504x4Extended
Thanks for the updated info, but I found the Bilstein shocks at eshocks.com with a buy 3 get the fourth free special with free shipping.
winfordr
05-02-2002 12:39 PM
Quick Reply: 20% off shocks and brake pads
