Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
96 f-150 throttle body
Old 05-23-2009, 04:02 PM
mickey6566's Avatar
mickey6566
mickey6566 is offline
Any suggestion will be appreciated.I have a 96 f-150 5.0,went to change the coolant and found a small hole in the bottom coolant elbow attachted to the throttle body.Went to investigate the hole and the peice came off in my hand.Guess I was lucky to be home.Does anyone know any fixes or am I bound to buy the complete throttle body assembly?Thanks
Old 05-24-2009, 12:04 AM
Blurry94's Avatar
Blurry94
Blurry94 is offline
Can you post a pic?
Old 05-24-2009, 03:03 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
MAF or SD truck?
and got a pic?
Old 05-24-2009, 05:54 AM
lew52's Avatar
lew52
lew52 is offline
Its the coolant line that keeps the TB warm in the winter time . If you live in a warm climate you can just bypass it ?? . If not ?? I think the fitting is pressed in , dont know if they sell them . You may need another TB . Lew
Old 05-24-2009, 08:34 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
If the exhaust gases recirculate from the heads through the intakes, to the throttle body, you'll need to plug the exhaust gas port at the lower intake to keep the throttle body from getting too hot.
Old 05-26-2009, 10:50 AM
Beechkid's Avatar
Beechkid
Beechkid is offline
If you have or can fab up the pieces, i bet JB Weld would work well.
Old 05-27-2009, 01:04 AM
my94lightning's Avatar
my94lightning
my94lightning is offline
I believe that the 5.0 and "standard" 5.8 truck have dual bore TB's. the coolant line is there to "cool" the throttle body, the egr valve (very hot) heats up the TB and the coolant is there to keep it from over heating the TB.
if you have deleted or deactivated the EGR, than you can either bypass the lines togetter or cap them off.
If the EGR is still active then maybe you can drill and tapp new hose fittings to the TB, dunno, but I would try that before buying another one.
good luck.
beerfart
19
03-20-2010 04:27 PM
aj197816134
02-07-2010 07:19 AM
ga73f100
10-29-2006 06:46 PM
rsmack
08-31-2004 12:12 PM
camo 24
05-10-2002 10:15 AM
Quick Reply: 96 f-150 throttle body
