'92 F150 Nite (4x4)
Old 04-13-2001, 03:28 PM
mikes66's Avatar
mikes66
mikes66 is offline
'92 F150 Nite (4x4)
I'm seriouslly considering picking up this truck next week that i came across last weekend on a truck lot near home, i drove the truck and everything seemed to be in pretty tight order (other than a check engine light) and was wondering if anyone could give me an idea on what specifically i might want to give a good look over on the truck. It has the 5.0 V-8 with 87,500 miles, body has been repainted (i asked and it wasn't involved in an accident), the 4x4 works good. On the lot at $5995.00, i've got em down to $5600.00, so far :-)
Thanks for the help & advice.
Buy AMERICAN
FORD #1
Old 04-13-2001, 06:45 PM
Pastmaster's Avatar
Pastmaster
Pastmaster is offline
'92 F150 Nite (4x4)
[font size="1" color="#FF0000"]LAST EDITED ON 13-Apr-01 AT 07:46 PM (EST)[/font][p]To me that seems like an excellent price for only 86k. I would recommend taking the truck to a certified mechanic or gear-head buddy and have them give it a thorough looking over. Even if it does cost you a little, it's well worth it.
For specs, the truck has
a 5.0L w 195hp/270ft/lbs of torque
9.0 compression
Borg-Warner 13-56 transfer case
Dana 44IFS front axle
Ford 8.8" rear axle
It would either have a E40d or AOd for an automatic or a Mazda 5-speed. The E4od has a overdrive cancel switch on the shifter, and a OD,2,1 on the selector, and the AOD has OD, D, 1 in the selector. Both are good, just one is electronically controlled and the other vaccum. I would say it probably would get around 16mpg on the highway and 12-13 in the city.
Old 04-13-2001, 08:30 PM
mikes66's Avatar
mikes66
mikes66 is offline
'92 F150 Nite (4x4)
Thanks for the reply and specs on the truck, i was wondering about gas mileage just outta curiousity. Considering he started out at $6995.00 on the website i figure it's worth the money. You can see the truck at www.sprinttruck.com, follow the trucks link.
Any idea's on the check engine light?
Buy AMERICAN
FORD #1
Old 04-13-2001, 09:04 PM
westerner1's Avatar
westerner1
westerner1 is offline
'92 F150 Nite (4x4)
Run a code scanner on it. You can get one for around $30-40 at Sears or your local parts store. More than likely, it's time to replace the O2 sensor.
1990 F150 4x4 LWB. 302HO motor. K&N Filter charger. ZF-42 Tranny. 4" Stage 2 Pro Comp Lift. 4.10 gears. 33-12.50 Pro Comp AT tires.
Old 04-14-2001, 07:51 PM
jamden's Avatar
jamden
jamden is offline
'92 F150 Nite (4x4)
That new paint might be covering rust in the box wheel wells but a '92 shouldn't have too much rust anywhere else, even in an area where winter salt is used. Like was said above, have a trusted mechanic go over it from one end to the other, oil pressure, compression, front end, u joints (theres 5 in the 4X4) etc. If the dealer has a problem with this, walk, he's hiding something. It cost me $75 to have it done on mine. That $75
saved me at least $3-400, things my mehanic told me that needed doing and the dealer ended up doing for me as part of the purchase price. For reference, in Feb 2000 I paid $8500CDN, about $5500US for my truck with 52K miles on it.
1992 F150 Custom, Supercab SB 4x4 302 AOD 3.55 31x10.5 All Terrain on Ford 15x8 Ralleys
Old 04-19-2001, 04:09 PM
mikes66's Avatar
mikes66
mikes66 is offline
'92 F150 Nite (4x4)
tje2015
17
03-23-2012 03:01 PM
mrshark
Escape & Escape Hybrid
13
03-26-2010 06:08 PM
stoney00
1983 - 2012 Ranger & B-Series
02-16-2008 03:50 PM
caleb
1999 to 2016 Super Duty
07-03-2007 07:41 AM
DaddyOutlaw
08-15-2003 08:53 PM
Quick Reply: '92 F150 Nite (4x4)
