1964 f100 steering column
Old 05-17-2009, 06:00 PM
rrtmpmm's Avatar
rrtmpmm
rrtmpmm is offline
im switching from a 3 on the tree to a automatic and my column is wore out is there a aftermarket or other one i can bolt in easily the automatic will be a floor shifter i also prefer a tilt.
Old 05-18-2009, 12:26 PM
garbz2's Avatar
garbz2
garbz2 is offline
Steering shaft for a 64 is a solid shaft and box type.
No columns other than a 61 to 64 truck will bolt in.
You can modify the existing box and shaft to accept an aftermarket tilt. Machining of the steeriring shaft stub and fabrication of a new lower mount will be needed.
I have a 88 Truck tilt in my 64 modified to fit.
In your stock column you say it is wore out? There is only a single replaceable bearing in there. Describe wore out.
Garbz
Old 05-18-2009, 06:06 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1961/64: There are two steering column bearings and retainers.
One bearing and retainer fit into the upper flange at the top, one of each fits into upper flange at the bottom.
2) C3DZ3517A .. Bearing
2) B1AZ3518A .. Retainer.
Both these parts are available from Ford and fit Mustangs, Falcons, Fairlanes and other 1960's cars.
1965/72 columns use the same bearings and retainers, but are in different locations.
One each is in the upper flange at the top, one each is at the bottom of the column.
Old 05-18-2009, 08:10 PM
rrtmpmm's Avatar
rrtmpmm
rrtmpmm is offline
it has a lot of play side to side and seems loose
Old 05-19-2009, 09:44 PM
garbz2's Avatar
garbz2
garbz2 is offline
How big is the gap between the steering wheel and the shift hub?
Garbz
Old 05-20-2009, 11:28 PM
Ruxton5's Avatar
Ruxton5
Ruxton5 is offline
I don't mean to hijack any thread, but I have the same problem, cept' in the 65. Numberdummy, Do you have a diagram for the 65 f100 steering column with column shift. My steering is getting very sloppy and I noticed just below the bottom flange that the bearing ring is almost hanging out. It needs attention now. Any parts list online?
Old 05-20-2009, 11:42 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Pro-Street/StateTK is offline
rrtmpmm
Welcome to (FTE) !
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx
Ruxton5
Welcome to ( FTE ) !
You will need to check your ( Cab Mounts ) if they are wore out or rusted rotted then
as soon as you rebuild that Column it will be in the same shape real Soon ! So check
and repair or replace if needed !
Wally Womack
09-26-2023 02:47 PM
WilliamKG88
09-15-2015 08:39 PM
Thood81
07-08-2013 03:29 PM
bpatton74
WTB - Parts & other
13
06-23-2012 03:29 PM
74lowf100
03-12-2006 07:48 PM
Quick Reply: 1964 f100 steering column
