86 f-150 302 wont start
i pushed switch down no change.when i switch over to gas and turn the key i can here the rail pump buzz for a few seconds. could it be anything to do with the oil pressure switch that activates the relay? if so where and how do i check that?? thanks for the sugestions guys, please keep them comeing i really need to get this truck running on gas
on your starter relay there should be your two large wires and two small ones.one is to energize the relay,the other one turns the pump on while you are cranking the engine only. you could jump this out with a live wire and see if it starts.the relay should be by the power brake booster.i believe there is a fuel pump wiring diagram in the stickies area.good luck
help.!
so far I have half tank of gas,new fuel pump in tank,rail pump buzzes for a few seconds when i turn ignition on. new fuel filter. Inertia switch is good.I checked dual fuel switch and it works proper.Relay switch has power going to it from the solenoid relay when i turn the ignition on.The only thing i havent tried is pull the line of in front of the fuel filter to see if fuel is actually being pumped through since I dont smell any gas when turning the motor over
Well guys I finally got it running on gas.I pulled the fuel line of in front of the rail pump.I turned the ignition on ,listend for the buzz at the rail pump then checked to see if there was fuel in the bucket I put below the line,which there was.I turned the truck over and holy crap it fired up.Ran it till it died and then I hooked the fuel line back up.Turned the ignition of and on a few times to pressure up the system and it fired back up and ran.IT now runs awesome,maybe it was vapor locked I dont know.Thanks guys for all your help and sugestions !!!!!!
BluecreekGT
Alternative Fuels, Hybrids & Mileage
03-08-2013 09:29 AM
krol
04-01-2008 10:04 AM
krol
03-20-2008 03:54 PM
