Recommend, or Not, any Local Roofing Companies?...
Hey All, We've got some wind damage to our 20yr old roofing shingles. I'm calling around for qoutes. Anybody have any recommendations, or companies that I need to stay away from? FYI, Home Depot charges an arm and a leg for their roofing products and local installer services.
Not to steal your thread, but what about heater/air contitioner people. I have a unit that needs to be serviced every spring. I've called several companies, but no one wants to check for leaks. With R22 going the way of R12, I need to do something.
I use T&M heat and air out of broken arrow. They can service just about anything. R22 is now out also all units being made now are using a new refrigerent. If any thing goes out not you got to replace the entire system.
JW, thanks for the reply. I will write that name down and see what they say. If I have to replace the unit, then I'll be waiting for next spring. If I replace one, then I might as well replace both units. Unfortunately, 2 story house means 2 units
