1983 - 2012 Ranger & B-Series All Ford Ranger and Mazda B-Series models
What are symptoms of bad lower ball joint
Old 05-06-2009, 06:37 AM
pgw85706's Avatar
pgw85706
pgw85706 is offline
I hear a random knocking in the front suspension, a clunk when the brakes are applied, and I see the rubber boot is missing from the drivers side lower ball joint.
What can I do to determine if the ball joint is suspect? Something like jack up the front end and see if there is top to bottom "slop" in the wheel?
Thanks.
Old 05-06-2009, 08:56 PM
pawpaw's Avatar
pawpaw
pawpaw is offline
Well if the dust boot is gone, so will the ball joints lube & moisture & grit can get in there & do dastardly deeds.
You can raise the front end on stands & use a jack, or rig a pry bar with a 2X4 or something that'll raise the tire while you view the ball joint area. It shouldn't have any visable play.
Grnding noise when turning, or maybe clunking when going over bumps, uneaven tire wear, vehicle not wanting to steer a straight line on a road with a high crown, or maybe it wanting to wonder in a cross wind & of course play in the BJ when unloaded, are some signs that they need changing.
My dust boots were cracked at 60K miles & the BJ's made a popping noise when turned well off center & when raised they had easily seen unloaded play.
I had both upper & lower "A" arm BJ's replaced on both sides, on my 4X2, as the upper dust boots were cracked too, along with an realignment, then put new Michelin LTX M&S on it last fall.
If your BJ's are so badly worn that they're clunking, don't wait to replace them as it's not safe if they're that worn.
paintubturner
05-04-2017 01:42 PM
tssngs75
1999 to 2016 Super Duty
11-18-2014 04:24 PM
scsprop
09-18-2014 09:22 PM
jeeplj8
02-04-2012 01:19 AM
boosteddsm
06-15-2011 09:44 PM
Quick Reply: What are symptoms of bad lower ball joint
