1994 f 250 xlt f250 xlt dually diesel
Ford made a f 250 xlt for 1 yr..dually..1994 only..please take a look at my pics then call ford..i have all the official paper work from the factory....diesel..power stroke 7.3..they didnt make many but i got one and ford did make them....call ford and check...it only has 40,000 miles....mint condition..power stroke
My truck is a f 250 ford 1994 with a conversion
In richmond va there is at least 50 of these trucks running around with either gas or diesel motors...1994 only was the only yr this truck was made in a dually..i have the origianl paper work from the owner that i bought it from..says ford dually..1994....its legit.............call ford the actual factory...they made a dually in 1994 f250..that was the only yr
Beautifull truck but Ford did not make a F250 Dually,nor did they make a 4x4 dually pickup untill 99.It is clearly a conversion probablly Centuion.Ha sall the tell tale signs of a conversion.the cab fairing,ground effects,grille gaurd,the body side mouldings which a dually does not have.I would bet there is some kind of custom interior pieces like an oak console or overhead console.Centurion converted these trucks right out of the box new and were sold at certain Ford dealerships that is why there are a lot of them in your area.Non the less it is a sweet truck that I would be proud to own.
Hello
It has a over head shelf inside on both sides..bucket seats..plush..electric remote start....separate wiring switch to turn on the run lights..separate switch to turn on for lights..well the owner who i bought this from told me it was original..well none the less its a good truck and i guess the guy is a fibber who sold it to me....it has a power stroke 7.3......we are having the truck airbrushed with a screaming eagle harley davidson logo/lil bit at a time........im trying to find more led lights to install on it as of now.....i have seen some led lights that go on the tail gate and it says ford..cant wait to get it done to put the pics up
Ford made a dually 4x4 before 99 I beleive.
I do believe Ford made dually 4x4's before 99 as well too.
Everything on your truck may be original, but not factory. Centurion moddified quite a few things for Ford from the F250 Bronco thingy (prehistoric Excursion), 6 door F350's, 4 door F150's, and a few others. These trucks went straight from the line (sometimes incomplete) straight to the Centurion shop then the trucks went to the dealers.
Wait, what? When the monobeam D60 was brought back as factory equipment in 1985 the 4x4 dually trucks were exactly the ones that got it, and in 1986 the D60 was installed in all 4x4 F350s, SRW and DRW. Dunno about '80-'85, but starting the end of the 1985 model year Ford has been making 4x4 duallies. Now, they didn't make a 3/4-ton dually, not since the '70s at least, so this is definitely a conversion.
