Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
It has begun....
Old 04-12-2009, 10:10 PM
flysniper's Avatar
flysniper
flysniper is offline
It has begun....
Not sure where its going to end or how I'm going to get there. Guess we'll find out.
1978 Ford F100 Explorer
Rebuild, restore, re.......whatever.
Follow along: Project F100
The blog is a little different.
We're going to present the project from two points of view. Mine...and my wife's. This ought to be interesting. Maybe even a little humorous.
Old 04-17-2009, 10:54 PM
Chaosracing's Avatar
Chaosracing
Chaosracing is offline
what did you use to set up the blog? I will be keeping an eye on it, especially to see what the wife has to say. I am kinda in the same situation you are, I got my 47 ford truck from my Father in law as well.
Old 04-18-2009, 01:08 AM
BradyCouchman's Avatar
BradyCouchman
BradyCouchman is offline
i started a engine removal and replace having never done it before. i read some books and some posts and just went for it. its a great way to learn. i am lucky that my truck is not my dialy driver and could sit for a week or 2. good luck!
Old 04-18-2009, 06:12 AM
flysniper's Avatar
flysniper
Chaos - I'm using Blogspot. http://www.blogspot.com It's owned by google and therefore works really well with the Google suit of products, specifically picasa which is used to manage pictures. Its pretty intuitive. I'm no expert, but if you have any questions let me know and I'll try to answer them as best I can.
Brady- thanks for the encouragement. I'm looking forward to getting my hands dirty. I too have the convenience of it not being my primary driver so it can be out of commission with out affecting me too much. Although it does take up more space than I imagined. And I suspect it will be down for a little more than a couple weeks. Let's put it this way, I stopped paying insurance on it.
I'm going to try to update it once a week, at least when I'm able to accomplish something.
stay tuned, found some not-so-interesting stuff this week.....new entry will be going up on Sunday, SUNDAY, sunday........saturday's only!
Mike
Old 04-18-2009, 07:56 PM
Customcab's Avatar
Customcab
Customcab is offline
Like the blog and especially the misses point of view; I've never seem to understand my wife thoughts on my trucks but its good to she her view as well. I'm almost at paint stage on a 78 model for my 15 year old daugther as her 1st ride. I got till mid july to finish. Havn't posted any recent progress, but today painted the grille insert and did both round & square light bezel; havn't decided on which ones, more than likely will us square, they look better on 78 & 9's model.
Enjoy your post and looking forward to seeing more progress.
Mitch
Old 04-19-2009, 07:49 AM
flysniper's Avatar
flysniper
Mitch-
I love your work on the 78'.
I would like to pick your brain about getting the frame and suspension components so clean. Can you provide any insight?
Mike
Old 04-19-2009, 09:34 PM
flysniper's Avatar
flysniper
blog has been updated.
Old 04-22-2009, 08:46 PM
liftnw8z's Avatar
liftnw8z
liftnw8z is offline
(CL) Team Brahma
It's fun seeing both sides of the story - yours and your wife's. Looks like the latest pics show some serious floor pan rust...salvageable?
Old 04-23-2009, 08:21 AM
flysniper's Avatar
flysniper
I think so.
A couple of replacement floor pans will fix the foot area.
but I'm concerned about the rot between the seat and the rocker panel.
I THINK the rocker panel is solid, but I'm not sure where I'm going to find a replacement metal for that section of the floor. I may just have to fab a piece up. The angles "shouldn't" be that big of a deal.
I have limited experience, so I can't say for sure.
I'm still researching.
Mike
Old 04-23-2009, 09:54 AM
BradyCouchman
i would say buy a parts truck that might not run so it would be cheep, but only if it doesnt have any rust.
Old 04-23-2009, 11:32 AM
flysniper's Avatar
flysniper
A whole truck?
I just got one area that won't be fixed by a new floor pan that's 12" X 6" inside the cab to fix. Do I really need a whole truck?
I don't know, that's why I'm asking.
Old 04-23-2009, 02:58 PM
Chaosracing
No you dont need a whole truck. Go to a U Pull it yard and see if you can find one in decent shape in that area and have them cut it out for you. Or fab up the section you need to replace and weld it in. Looking at the pic on your blog, that is a typical spot for rust for some reason onthe old pickups and broncos. Also check out yor front cab mounts on the cab. They tend to rot out as well. You also might have to either replace or reinforce the frame mounts for the cab because they usually rusted out and got thin.
I dont want to scare you, but I have seen this on alot of these style trucks.
Old 04-23-2009, 03:02 PM
flysniper's Avatar
flysniper
I an't scared.....
yet
I'm surprised I haven't seen more to be honest.
I'll pay special attention to the cab mounts this weekend, if the weather cooperates.
Any other areas of interest I should be paying special attention to?
Old 04-23-2009, 03:10 PM
Chaosracing
On these style trucks its mainly the cab mounts, floors and frame mount locations. But also check the frame where the coil spring buckets are and where the rear leaf spring hangers are as well as any cross members. Rear spring hangers and front spring buckets are notourious for pushing apart due to rust between the frame and the piece. Easy solution is to remoce the rivets, remove the bracket and clean up frame. Repair if necessary. Paint everything with POR15 (or your choice of paint) and bolt everything on using 7/16" grade 8 bolts and locking nuts (or lock washers) I guarentee the frame will out last that truck and probably most other trucks as well.
On the body the bottoms of the fenders can get a little rusted out, and the bottom front of the hood also can rust out on these. But if you have seen any signs yet, all I would do is undercoat those areas.
Old 04-23-2009, 03:17 PM
flysniper's Avatar
flysniper
The $1MM question, POR-15 or Eastwood Rust Encapsulator? Inquiring minds want to know. I've done the search and I've read the posts.
I've flip flopped 1/2 a dozen times. Currently leaning toward the Eastwood product. I need to decide because I'm guessing I'm about 3-4 weeks away from using what ever it is I decide to use. Method of application is a major consideration. I need to be able to do it at home and I don't have spray equipment.
Last edited by flysniper; 04-23-2009 at 03:20 PM. Reason: I can't spell and I can't speak english...
Quick Reply: It has begun....
