P0402 Exhaust Gas Recirculation Flow Excessive Detected
Old 04-11-2009, 07:56 PM
scott4401's Avatar
scott4401
scott4401 is offline
Hello, I have a F150 4.6 liter with 85000 miles on it and I keep getting the Code P0402 Exhaust Gas Recirculation Flow Excessive Detected. I have changed the DPFE sensor and the EGR Valve and the EGR Vacuum Solenoid. Basically everything in the chain of the Vacuum lines. I cant seem to get this code to go away and I think it is affecting my gas milage to. Any help on where to go next would be appreciated. Thanks
Old 04-11-2009, 09:34 PM
dadlovesfords's Avatar
dadlovesfords
dadlovesfords is offline
Did you remove or replace the filter at the EGR valve. Easiest is to just remove it , and clean housing out with throttle body cleaner.
Old 04-11-2009, 11:44 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Here is an example of knowing what the 402 test is doing.
Basicly the PCM looks at the DPFE with the EGR closed such that no flow is supposed to occurr.
How it detects this is the DPFE sees the same exhaust pressure on both sides of the calibrated orfice indicating there is no flow or 'pressure drop' accross the orfice.
If there is a leak in the pipeing off the exhaust manifold, any hoses are leaking that connect the DPFE to the test tubes or a leaking EGR, the DPFE will not signal the pressure is the same on both it's ports. (sort of like a 401 test when it is not the expected results of the test)
This test is done at cold startup-drive-away to use the extra exhaust pressure of the motor as it is increasing in rpm.
Inspect closely the metal tube at the exhaust for cracks, rust holes as well as the DPFE hoses and small connecting tubes for a problem.
Test the operation of the EGR to be sure it is seating closed.
Test that the vacuum control that operates the EGR is allowing the EGR to close because it is a 3 port device that must let air into the EGR once it has been opened so it will close again and not hang up.
Good luck.
Old 04-12-2009, 06:45 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
...and make certain that your new DPFE sensor came from Motorcraft, not an aftermarket supplier.
Old 04-13-2009, 11:22 AM
scott4401's Avatar
scott4401
Why does it matter if you put a mororcraft part on it I believe the one from Rock Auto was a AC Delco.
Old 04-13-2009, 11:24 AM
scott4401's Avatar
scott4401
Do you mean to just remove the EGR Valve and then retrieve the filter or do I have to remove the entire throttle body?
Edogsf350
06-07-2016 08:54 PM
2horses
6.7L Power Stroke Diesel
62
04-08-2016 02:10 PM
Duckman77
05-13-2013 08:37 PM
nutmg1
10-30-2012 05:45 AM
deejdeej
1983 - 2012 Ranger & B-Series
06-10-2010 09:51 PM
Quick Reply: P0402 Exhaust Gas Recirculation Flow Excessive Detected
