Dodge Dakota IFS / Frame Swap
Either the "search the forum" button is not working right for me or no one on this site has done or even talked about a Dodge Dakota / F100 frame swap. I've searched and searched and keep coming up with nothing.
I know that Industrial Chassis makes a cross member kit to put a dakota IFS under an F100 but has anyone put the whole frame under theirs?
I have a '53 F100 with a Volare setup and am not happy with it and would like to go with something else. I've heard good things about the Dakota IFS.
Just looking for more info. Those of you that have the IC dakota crossmember set up 'Do you like it'?
And has anyone done a complete frame swap?
Thanks
Thanks
If I were to put an IFS on my truck it would be the Industrial Chassis Dakota setup.
Of all the swaps available its the only one design from a Truck setup.
The Dakota Front end is factory rated about 1000 lbs more than the stock suspension.
It has a built in drop and also has dropped spindles available.
I've talked to Steve from IC several times.
(I still drool when I look at the setup.)
Old Uhaul do you have any pictures so far? Does the cab fit on the frame nicely or is it going to take some work to make it fit? Are there any other major complication you for see in making the swap? I'd be inerested in any pictures or info you have. Without stripping the truck down and seeing the bare frame it's hard to get a good idea of any real challenges this swap would pose. I know the bed floor in the box will have to be raised to fit the dakota frame. But other than that from what I've seen things should fit pretty well. Good luck I'll be very interested to hear how this goes for you. I think this next week I'm going to start looking for a dakota.
V8R, Eric, would you give me a call? I want to talk to you regarding the Industrial Chassis Dakota IFS installation in your F1. Neither of us have enough posts on this forum to send PMs.
I have talked to Steve at IC and came away with the impression that he no longer builds a Dakota IFS for the '48-'52 F1 chassis.
Please give me a call so we can share some information. 217 932-4956(home) or 217 663-5252(cell). Thanks, Tim
65fordguy
08-03-2011 06:46 PM
53lover
10-14-2009 07:42 AM
64Blubyu
21
07-11-2009 03:37 PM
