Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
sugar in the gas tank.
Old 10-25-2001, 07:34 PM
red94cobra's Avatar
red94cobra
red94cobra is offline
Old 01-08-2002, 09:58 PM
redneckdieselmechanic's Avatar
redneckdieselmechanic is offline
I got a friend with a 00 lightning and some punk put a pound or more sugar in his gas tank. He said it woudlnt run over 20 miles an hour and it would always bog out when he pushed the gas tank. I'm just wonderin what kind of damage this does to the engine.
Old 01-11-2002, 06:57 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Clogged injectors and if it gets through the injectors, it can score the piston rings and cause all sorts of nasty stuff.
Old 03-10-2002, 01:50 AM
Lightning Rod's Avatar
Lightning Rod
Lightning Rod is offline
"I got a friend with a 00 lightning and some punk put a pound or more sugar in his gas tank."
Probably some retard who had his *** handed to him while racing the Lightning. Some people don't deal with defeat very well.
Red 2001 Lightning with stock drivetrain
13.61 @ 102 MPH spinning factory F1s.
[B]RUNVS?
Old 03-12-2002, 11:01 AM
texan_eagle_scout's Avatar
texan_eagle_scout
texan_eagle_scout is offline
I was under the impression that since sugar won't disolve in gas that it would just plug/clog up the filter, thereby restricting fuel flow. That sounds like what would allow him to only get up to 20 mph. Could a person remove the plugged filter, while opening the fuel line into a empty gas can or other container to drain the sugar, or would this require dropping the tank?
Old 03-13-2002, 11:36 PM
Red F150's Avatar
Red F150
Red F150 is offline
I think dropping thank would be the best bet since most have a sock looing filter inside the tank. If you clog up the sock filter it just sucks closed especialy if the pump is in the tank.
One more sugestion, locking Gas cap. When your fast your bound to **** someone off.
Old 03-17-2002, 11:41 AM
Lightning Rod
Putting sugar in a gas tank will get you shot down here in Texas. It's right up there with cattle rustlin' and horse theivin'.
