location of the PCV valve?
Old 04-01-2009, 02:23 PM
imabor's Avatar
imabor
imabor is offline
Red face location of the PCV valve?
I have a 2003 V6 F150 and I am trying to find where exactly the PCV valve is? It is not in the location that the Chilton Manuel says it is? Can anyone offer up a diagram?
Old 04-01-2009, 02:56 PM
imabor's Avatar
imabor
imabor is offline
PLEASE HELP! I'm getting desparate here.
Old 04-01-2009, 03:34 PM
KingRanchMan02's Avatar
KingRanchMan02
KingRanchMan02 is offline
I don't have a V-6 in my truck like you but, the PCV valve in my truck is in the passenger side valve cover. Pictures of it in my photo album. Good luck!
Old 04-01-2009, 03:39 PM
bowdog's Avatar
bowdog
bowdog is offline
On the passenger side right in the middle of the valve cover, Hope this helps
Old 04-01-2009, 03:58 PM
imabor's Avatar
imabor
imabor is offline
Thanks guys you are awesome! I was tired of being treated like I was retared at the local parts store. I dont know if it was because I'm female or because I dared to question the all knowing Chilton.
Old 04-01-2009, 05:59 PM
KingRanchMan02
Welcome to FTE imabor! Glad we could be of help!
Old 04-03-2009, 10:00 PM
al52269's Avatar
al52269
al52269 is offline
The milky residue you see on the oil cap is a common symptom of a bad PVC system.
PCV Basics
PCV stands for Positive Crankcase Ventilation.
All car engines have a PCV valve and it is located on top of the motor's valve cover. There is a vacuum line attached to it. It pulls out of the valve cover and if you shake it, you should hear a marble knocking inside it. If you shake it and don't hear anything, it's bad. It costs less than 5 bucks to replace.
Location
· 4.0L is located in the valve cover near the brake booster
· 5.0L is located behind the intake manifold (engine rear)
PVC Valve
Removal & Installation
1. Disconnect the oil separator hose from the PVC Valve.
2. Remove the PVC Valve from the grommet in the crankcase.
Grasp the valve and gently remove it from the grommet in the passengers side valve cover. Remove the valve from the hose by carefully twisting it out.
3. Inspect the grommet for deterioration.
To Install;
4. If necessary, replace the crankcase grommet.
5. Install the PVC Valve.
6. Install the hose.
Old 04-03-2009, 10:07 PM
rambaseball45's Avatar
rambaseball45
rambaseball45 is offline
on my 97, 4.6L its located on the drivers side of the engine, pretty cose to the intake system
chuck7300
09-06-2008 02:38 PM
BAJI26
03-16-2008 01:24 PM
randy6800
1983 - 2012 Ranger & B-Series
03-13-2008 07:06 PM
harryvil
Escape & Escape Hybrid
09-18-2007 07:08 AM
paisano341
11-19-2003 08:00 PM
Quick Reply: location of the PCV valve?
