Tennessee Chapter Join Chapter Leader: harleymsn
memphis area, anyone with a good scanner and experience?
Old 03-29-2009, 11:58 PM
hgoody77's Avatar
hgoody77
hgoody77 is offline
needing some help with my 99 F250 7.3L. i ahve some issues with the way it's running and i thought maybe i would check with the forum here to see if anyone has a scan tool and experience with these motors?
Thanks, Howard
Old 04-01-2009, 09:42 AM
lariat97's Avatar
lariat97
lariat97 is offline
I have a SCT tuner that will scan most of your problems. I can let you use it when ever you want. Its vin locked to my old truck but it will still scan most Fords up to 03 models. I use it to scan my car when its check engine light comes on. I can also get the diesel tech from Landers Ford to fix it after hours if it needs repairs. You would have to bring it to Collierville.Let me know if you are interested. I need a day or 2 to get in touch with him. He can borrow the Ford scanner & find any problem you have.
Old 04-01-2009, 10:36 PM
hgoody77's Avatar
hgoody77
hgoody77 is offline
Lariat97, Thanks.
right now it's at the shop getting that oil leak fixed on the turbo. I wished there was a way to test or repair that TSperformance chip. would like to keep it but it makes it run a little rough i think. I will remember you though if i need some other work or need to scan it again i hope it will all be worked out this time.
F-250 restorer
44
04-10-2014 09:52 PM
engine14
03-27-2014 02:16 PM
engine14
03-26-2014 02:55 PM
HMS
1999 to 2016 Super Duty
12-02-2009 10:42 PM
Howard
06-15-2005 09:53 PM
Quick Reply: memphis area, anyone with a good scanner and experience?
