West Virginia Chapter Join Chapter, Leader: 5_labsownus
'05 PSD Block Heater Plug
Old 03-25-2009, 09:14 PM
Kanyonkitty's Avatar
Kanyonkitty
Kanyonkitty is offline
I have an '05 6.0 PSD and I usually plug it in overnight. I notived 3 days ago, that my extenson cord had a melted spot on it, it's the same cord that I used last year. So, I put a new end on my extension cord, and it was again melted. SO, this morning when I unplugged my bus, I put that extension cord on my truck and when I came home 3 hours later, that cord had the beginning of a melted spot.
I took a closer look at the plug end on my truck and one of the "blades" was discolored and VERY LOOSE. Needless to say that cord for the block heater is really buried in there and super hard to get to, so can I just remove the plug end and put on a new plug ? And is it something that I might be able to do ?
Thanks for any help & information,
Kitty
Old 03-25-2009, 09:17 PM
EMD_DRIVER's Avatar
EMD_DRIVER
EMD_DRIVER is offline
Yep and it's a whole lot easier, than trying to replace the whole cord!
I don't know if the PSD cords are the same as the IDI, but I believe the entire cord can be replaced... If yer feelin froggy!
Old 03-25-2009, 09:20 PM
Kanyonkitty
Thanks Gary,
And I took a look to see where the cord was routed, and "no thank you" for replacing the entire cord, what a freakin nightmare. I'd have to be a contorsonist to replace it.
Kitty
Old 03-25-2009, 09:22 PM
EMD_DRIVER's Avatar
EMD_DRIVER
Kitty
Hmmmmmm! Might be time for a complete-with-pics write-up!!!!!
Old 03-25-2009, 09:30 PM
Kanyonkitty
UMM, well since you thought of that, I'll provide the camera and the truck and you can figure out how to make your body parts fit where this cord goes You've seen under the hood what a jammed up mess is in there, that's why I'd rather try replacing the plug end first
But, I'm willing to drive it over for you to do it
Kitty
Old 03-25-2009, 09:35 PM
EMD_DRIVER's Avatar
EMD_DRIVER
I'll put a new end on it, if that's what you want... If the cord gets replaced, it will be YOU doing it with me TAKING the pics!
Old 03-25-2009, 09:48 PM
Kanyonkitty
Oh gosh, I sure hope a new plug solves the problem, as for the other scenario, well, I'd rather not go there
Where do I get the plug end, find a dead PSD in a junk yard ?
Kitty
Old 03-25-2009, 09:52 PM
EMD_DRIVER's Avatar
EMD_DRIVER
Kitty
Lowes would be my first choice...
Old 03-25-2009, 09:55 PM
Kanyonkitty
I might try the bus garage
Old 03-25-2009, 09:59 PM
EMD_DRIVER's Avatar
EMD_DRIVER
I don't think they would have anything. If you aren't replacing the whole cord, your choices are a bit limited.
Old 03-25-2009, 10:08 PM
Kanyonkitty
Thanks Gary,
I'll get a new plug end tomorrow, and well, I might take you up on replacing it for me. Electrical stuff is not my favorite thing. I prefer power tools , I can saw, drill & hammer, but electric scares the bejeebees outta me,
Kitty
Old 03-25-2009, 11:00 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
If the cord routing is like an IDI, simple job from under the truck.
Old 03-26-2009, 05:39 AM
Kanyonkitty
Dave,
There is really really not much room ro run a new cord without it being a REAL nightmare of a job, so I'm hoping to try the new plug end first. Everything is just so darn jammed in under the hood, it's a real mechanics nightmare. "IF" the new end doesn't solve the problem, I'll have to get my bus mechanic to replace the complete cord I guess. He maintains my truck for me, as he does mechanical work on the side.
I sure wish it was as easy as an IDI,
Thanks,
Kitty
Old 03-26-2009, 12:39 PM
msgtg's Avatar
msgtg
msgtg is offline
Hi Kitty, I just replaced my plug on the truck about two weeks ago.
In my case, the wire had a nick right behind the plug and I kept getting shocked everytime I plugged or unplugged.
If you peel back that plastic accordian cover, you'll see that one of the wires is plainly marked "Neutral". That's pretty much all we needed to know. I clipped the wire right behind the head of the plug so as not to lose any wire length. We skinned all three wires back. I picked up a heavy duty yellow plastic replacement plug and wired it up. When we closed the plug, we stuck the end of the accordian cover between the two pieces of the plug so now it's covered completely...no exposed wire to get nicked.
Joe
Old 03-26-2009, 03:16 PM
Kanyonkitty
Thanks for the info., Joe
I'll relay that info to Gary, as he picked up a new plug for me today, and I will be heading over his house for him to install it this evening . The truck is nice and clean right now, but it's raining here so it will soon be dirty once I pull out of the truck-port and then the cleaning process can start all over again. Dang, why did I buy such a big monster
Kitty
Quick Reply: '05 PSD Block Heater Plug
