70's vintage 8000 lbs Warn winch
Old 03-25-2009, 10:07 AM
shack's Avatar
shack
shack is offline
Guys, I have been saving this old 70's model 8000 lbs Warn winch for just the right truck. Any tricks to bolting it up to the winch bumper? And does it matter if the cable comes off the top or bottom of the spool?
Joel
Old 03-25-2009, 11:02 AM
1977f150xlt's Avatar
1977f150xlt
1977f150xlt is offline
i am not a expert on winches and i myself am interested in the same question, and if you don't mind could you post some pictures of the winch and the truck planned for it? if you don't know how to just click this link below its a thread i started awhile back
https://www.ford-trucks.com/forums/78...-pictures.html
-Brent
Old 03-25-2009, 11:14 AM
1977f250's Avatar
1977f250
1977f250 is offline
What model is it? Most Warns bolt to a plate from the bottom as do most other makers unless you have a 7284 and that will bolt to the face of the plate but is the fastest winch Warn ever and still makes.
Old 03-25-2009, 06:34 PM
matt's77's Avatar
matt's77
matt's77 is offline
All the winches I've had or seen have had the cables come out of the bottom. You should be able to tell when you let it out or real it in. I have used battery cables to check if the winch works. So you could do that to see wich way the cable reals up.
There will be four bolt holes on the bottom of the winch. Just use some grade 8 bolts that fit and bolt to the bumper. Power cable goes to battery, find a good ground spot and you are good.
Old 03-25-2009, 10:49 PM
1977f250's Avatar
1977f250
1977f250 is offline
I think I would bolt it to a lot more than the bumper, well in less you don't like your bumper, and get yourself a ****** block to go with it. It will have a lot more pulling power with it. If you really get stuck I mean deep or in a place where you may have to drag your truck out it will really help there as a 8000# is really a light winch for one of these trucks.
Old 03-26-2009, 07:08 AM
lostinfords's Avatar
lostinfords
lostinfords is offline
Here is a pic of the winch and winch bumper from the 76 F250 that I bought in 1983, sold the truck but kept the set up to put on every other truck I owned, at present it sits on my 79 supercab, notice how the brush guard has the cut outs/protectors for the turn signals on the top and the headlights on the bottom, to correlate to the 76 model year. The cable comes off the bottom, if I remeber right it is a model #8274, it has been very faithful over the years. I also have the same model w/ a different bumper set up from my 74 crew cab.
Here as a pic of the 74 set up
Old 03-26-2009, 07:09 AM
lostinfords
this is the brush bar set up that goes w/ the 74 bumper set up
Old 03-26-2009, 05:22 PM
chapinmesa's Avatar
chapinmesa
chapinmesa is offline
Lucky you have that winch. I have a '70 highboy, and the push bumper even has a plate welded on where it looks like a winch once was, winches come in pretty handy
Old 03-27-2009, 02:15 AM
lostinfords
Thanks!!!!!
rowdyredneck
WTB - Parts & other
03-05-2017 11:48 AM
skibber
1978 - 1996 Big Bronco
01-19-2017 08:38 PM
Warn Industries
Vendor Specials, Discounts, Product Announcements & Group Buys
08-04-2016 01:00 PM
Thomas White
32
09-14-2015 09:17 PM
iggybob44
Offroad & 4x4
26
09-06-2011 09:42 AM
Quick Reply: 70's vintage 8000 lbs Warn winch
