HD tow pkg, or not
Old 03-22-2009, 07:26 AM
ron570's Avatar
ron570
ron570 is offline
HD tow pkg, or not
May buy a new 2008 left over expedition King Ranch, but it doesn't have the HD tow pkg. While I don't tow, I drive 100 miles per day highway with steep inclines. Is this a concern with heating the transmission and engine, or am I better off finding one with a HD tow pkg which includes bigger radiator & trans oil cooler.
Old 03-22-2009, 08:05 AM
thinksnow's Avatar
thinksnow
thinksnow is offline
If you like the truck that much just buy it. You can install a aftermarket trans cooler thats better then the factory system and they aren't too expensive.
Old 03-22-2009, 08:07 AM
ron570's Avatar
ron570
ron570 is offline
True, but what about the bigger radiator, alternator & battery? Also is the rear differential different in towing pkg?
Old 03-22-2009, 08:30 AM
thinksnow's Avatar
thinksnow
Well from reading your original post if you don't tow you don't have to worry about any of that. Even with steep inclines the stock set up should handle it just fine. I would still do the aftermarket trans cooler though. A cool trans is a happy trans.
Old 03-22-2009, 10:02 AM
chuck s's Avatar
chuck s
chuck s is offline
The only items in HD Tow I'm aware of are the slightly larger engine coolant radiator, the larger transmission cooler, and the seven pin wiring to the rear of the truck.
To my knowledge the alternator and battery are the same in all Expeditions.
HD Tow still has the 3.23 (?) axles in '08 and later. My '07 got the 3.73 as part of HD Tow, but I think that's now a separate option.
Transmission heat is a killer but most heat comes from the slippage during shifting. The Expeditions seem to lock up pretty quickly, even when towing.
If you're concerned get the Interceptor OBD2 gage, set it for transmission and coolant temperature, and put it on your dashboard. I doubt you'll note excessive temperatures but the gage will let you know what's happening. Just plugs into the OBD2 connector under the dash. Mine is just velcroed on top of the dash in a cheap pod.
-- Chuck
joegebff
04-29-2011 10:55 PM
royb
2009 - 2014 F150
09-28-2010 08:47 AM
dontrowell
2009 - 2014 F150
30
03-11-2010 04:58 PM
fordcountry
10-31-2008 12:51 AM
Quick Reply: HD tow pkg, or not
