Just got my first tank of bio
I just filled up with my first tank of b20. I plan on running this for a couple of tanks, changing the fuel filter, and then go up to b50 and maybe b100.
I think I have noticed less smoke, dont know if it is me or the bio, but I'm excited to step up to higher blends. Something about just loves the idea of bio.
What should I know be aware of?
Thanks
Bubba
Thanks
Bubba
Tom
Be aware of the gell point though, think Fabman said that as long as it doesn't get below zero 50% is safe. You might want to have different ratios in small sealed containers so you can track which ratios are good at your temp... different oils have different gel points, and it might varie from batch to batch unless you are getting it always from the same sources... Does give an idea though.
I just filled up with my second tank of b20 today. My average mpg 16.5
I was getting ~12 over the winter so I don't know how much of that is the b20 blend or how much is my driving/fixed a couple things on the truck but this is awsome I'm stoked with the mileage numbers. Can't wait for a couple more weeks to get some b50 and b100
The number after the "B' is the percentage of biodiesel in the "mix". B-20 would be 20% biodiesel and 80% dinodiesel. I make all my own biodiesel.
diesel mileage
Well, i have a 99' F-350 with the 7.3L Diesel Super Duty and have noticed the same thing...normally it gets 14-15 mpg and right now i'm getting a flat 11.6 no matter who's diesel i buy, or injector lubricant additives i put in. From what i understand, if you have the ebv removed (with a computer chip in its place) sometimes you can get better mileage (but wouldn't recommend it.) I can also tell you if you keep the block heater plugged in, you dont have to completely warm it up, just long enough for the coolant to really start cycling.
sknaggs185
sknaggs185
It is possible there is less smoke because BD is an oxygenated fuel thus there is less unburned fuel exiting the exhaust pipe as black smoke.
A more efficient burn can also account for your apparent increase in fuel economy.
