Bluetooth connect to f250 radio
Ummm. Thats odd. I do know that not all cell phones are compatible with the factory bluetooth. Just talked to a friend yesterday that had his Acura TL in for just that. He said that he could make a call through the system but could not answer one. They told him his phone was not one of the ones Acura had set up to accept. You should be able to go into the system and have it give you the option to select the phone you have and hopefully yours is listed.
Taken from page 125 of the 2008 "Navigation System Supplement (2nd Printing)":
Adding a new phone to SYNC
Note: This is a speed dependent feature. For your safety, this procedure cannot be completed if the vehicle is traveling at speeds faster than 3 mph (5 km/h).
Note: SYNC can store up to 12 previously paired phones.
This feature allows you to add (pair) a new Bluetooth enabled phone to
SYNC. To access:
SYNC. To access:
- Press the PHONE hard button on the navigation system.
- Select the ‘Settings’ tab on the touchscreen.
- Select ‘Add’.
- When prompted on your phone’s display, enter the PIN provided by SYNC.
SYNC. To access:
SYNC. To access:
- Select ‘Add’.
It is my understanding that this button is reserved for use with certain aftermarket phone kits--like the Mobile-Ease Hands Free System that Ford sells. Without one of these kits, the button does nothing of value.
http://www.fordaccessoriesstore.com/...~7L2Z_19G399_A
Bluethunder3320
10-25-2017 10:32 PM
