MBRP 7.3L Excursion Diesel Exhaust Sale!!
On Sale For Only $349.99 shipped to your door!
Ends March 7th at Midnight
To Order Call, E-Mail, Or PM anytime...
1999-2003
Ford Excursion
Turbo Back, Single Side
S6204AL
4" Aluminized Turbo Back Exhaust
KEY FEATURES:
Mirror polished T304 stainless steel tip
Delivers a rich, mellow exhaust note
Installs with common hand tools
Can improve fuel economy by 1-2 mpg
Boosts torque and horsepower
Complete Turbo Back System
The Best Systems Start With the Best Materials
Built from heavy duty aluminized steel our Installer Series performance exhaust systems offer a value price without compromising on the quality built into every component. While the seams are a major point of rust through with some budget systems our fully sealed tubing adds years to your system. Constructed to the same specifications as our top of the line Pro Series we back this line with an industry leading 3 Year Warranty.
Built to Perform
You count on your truck to tow all of your gear to where you want it. With your MBRPinc performance exhaust you can make that happen with up to 18 HP more horsepower and 28 ft/lb more torque. Give your truck more pulling power and much improved throttle response with an MBRPinc diesel exhaust system. Our systems are so much more efficient, it will be easy to see what your truck can really do.
Minimize Backpressure
The secret to getting more out of your diesel engine is to give it lots of cool, clean air. The only way that you can get fresh air in is to get the hot air out. From the spiral louvered high flow muffler to the fully mandrel bent tubing to minimal bend degree angles, your MBRPinc performance system gets exhaust out fast. Drop exhaust gas temperature by up to 200ºF and set the stage for all the performance you want. An MBRPinc performance exhaust system is the starting point to getting the most from cold air intakes, programmers, modules and downloaders."
Easy Installation
MBRPinc systems are as much fun to install as to drive with on your SUV. Bolt-on, no weld design makes installing this on your ride a no hassle one to two hour project. Everything is direct fit to the OEM hangers and you get all the clamps and parts you will need, all in one box, no matter what configuration of vehicle you have.
Sound & Style
Performance is one thing but at MBRPinc we believe that appearance and sound is just as important. Every MBRPinc performance exhaust system has been specifically tuned to get the optimal sound from your ride. With our MBRPinc brand etched on the tips and our unmistakable styling, there's no question that you have the hottest exhaust on the road - MBRPinc.
carid
Vendor Specials, Discounts, Product Announcements & Group Buys
01-29-2016 02:30 AM
Riffraff Diesel
07-15-2009 10:34 AM
Riffraff Diesel
03-12-2009 09:58 AM
