Brake pedal goes to floor
You guys are my last hope so here goes. 1993 F150 4x4. The truck has a hard brake pedal till i start it up and then i goes straight to the floor. The Problem Started out as a hanging caliper. Replaced pads and away i went. Half way home my pedal went right to the floor. Bled the brakes and not any better. So bought a Master cylinder and bench bled it, put back in and no better. Said hell it started with a hanging up caliper so ill replace them and the hoses that go to them. Did that and rebled and still no better. Figured the master i got must have been bad so got another one. No better. Bought a booster and still no better. All the lines on the truck have been replaced but 2 and theres no leaking. I have bled the proportion valve and abs valve. I'm at a loss. Everyone i talk to has no answers.
Any Ideas would be great.
oh If i push the pedal to the floor while driving i can get the right rear to lock up but that is it.
try sending a p.m. to "andym".
go to:
https://www.ford-trucks.com/forums/m....php?do=getall
then put in california for state and over to the right type in "andym"
in that list he is 3rd or 4th.
go to:
oh If i push the pedal to the floor while driving i can get the right rear to lock up but that is it. :-hair
I'll be watching
I'm having the same problem with my 95 250 PS. I haven't changed the booster or vacuum pump yet. I was going to change calipers, but maybe not now. Mine started with a stuck caliper as well. Got it unstuck and put new pads and it hasn't been the same since. Put in new master cylinder as well. Bled the thing at least 3 times. Same exact problem, but my pedal is a little soft with engine not running.
HawaiianPSD
10-11-2014 05:40 AM
85AustinTucker
03-07-2014 11:06 AM
