Forgot to connect Mass Air Flow connector - Whoops!
So, I changed my air filter yesterday.
Unfortunately, forgot to reconnect the Mass Air Flow connector before starting the engine. The Check Engine light and the "limp-mode" wrench lamp quickly came on to alert me that I had forgotten something. I reconnected the sensor and the wrench lamp went out but the check engine lamp is still on.
Am I going to need to get the lamp reset at the dealer? The manual indicates that the OBD-II sytem will clear some errors after 3 cold start cycles of driving the vehicle in mixed city/highway. Anyone have any thoughts on this?
Depending on how that particular sensor is coded, something like that usually will go away after 3-5 key cycles of the ignition. The Batt trick works on soft codes that don't store, but hard codes will stay usually until the ECM sees the correct information after a certian number of key cycles or the hard code gets stored until it is cleared by a code scanner.
leeg777
03-27-2007 06:56 PM
blue93explorer
08-16-2004 06:05 PM
