Mississippi Chapter Join Chapter , Leader: Scndsin
98 expedition won't start
Old 02-16-2009, 08:42 PM
marcsmithracing's Avatar
marcsmithracing
marcsmithracing is offline
this if a friend i work with she's got a 98 expedition 5.4 automatic 4wd. i've put a new silenoid, and ignition in it and still won't crank from the key... turn key to on position go under hood and bridge the silenoid and starts eveytime... i'm thinkning somthing like and ignition relay..... but the probleem is she doesn't have the owner's manuel so i have not the slightest clue where it's it it's got 2 fuse boxes under the hood both with realays in them as well as the usual under the dash fuse box with relays as well SOOOOOOOOOOO many realys and not the slightest clue which is what. HELP PLEASE
Old 02-17-2009, 05:46 PM
mxdadof2's Avatar
mxdadof2
mxdadof2 is offline
Marc,
I had a 00' expy and it would not start sometimes unless you held the gear shift all the way up.. If you look at the fuse box closest to the windshield standing on the drivers side that is where I believe that relay to be located it will show a list of them on the inside of the Lid ... Let us know how it goes
Old 02-17-2009, 06:22 PM
marcsmithracing
they arn't labeled on this 98 expy... thats why i was hoping someone mighta had an 98ish expy with there owners manuel to tell me which on too replace
Old 02-18-2009, 11:02 AM
mxdadof2's Avatar
mxdadof2
mxdadof2 is offline
oh ok sorry bout that...... Will see if we can come up with one for ya maybe ?? have you tried any of the other forums ?? maybe ask some one in there ?? hope you get it fixed soon
Old 02-18-2009, 12:27 PM
marcsmithracing
i got a thread posted in the expy section on this site but nobody has said anything about having the fuse boxes diagrams.
Old 02-20-2009, 09:14 PM
3golfjack's Avatar
3golfjack
3golfjack is offline
I,ve got a 89 f150 which had a similar problem a few years ago. The ignition switch on the lower steering column needed adjusted. I had to loosen the two screws on the top of it and move it slightly up the column. This allowed the linkage from the key switch to be able to engage the starter part of the ignition switch.This may not be the cause of you problem but its worth a check.
Old 03-05-2009, 06:26 AM
marcsmithracing
just so everyone know's i finaly got this expy fixed it just ended up being a shorted out wire to the silenoid. don't you just hate it when it's a simple thing?
Old 03-06-2009, 07:20 AM
BarryMc's Avatar
BarryMc
BarryMc is offline
How in the world did you track that down?
Old 03-06-2009, 07:47 PM
marcsmithracing
just followed the wire it's entirety and found where it decided to lay on top of the exhaust just enough to fry it.
Old 03-06-2009, 07:54 PM
BarryMc's Avatar
BarryMc
BarryMc is offline
on top of the exhaust just enough to fry it (Quote)
That'll do it every time
Old 02-17-2022, 10:47 PM
markcfistal7's Avatar
markcfistal7
markcfistal7 is offline
Replaced battery and starter. Go to start and just clicks
ROBSFX3
05-22-2015 01:56 AM
F350Jay
6.7L Power Stroke Diesel
11-26-2014 07:51 PM
hajduk
1997 - 2003 F150
03-19-2011 12:54 PM
WALJON
10-24-2010 10:33 AM
kkoles2000
19
07-08-2003 07:51 PM
Quick Reply: 98 expedition won't start
