Anybody using the Summit Dual Exhaust kit on a '93ish 5.0?
Old 02-15-2009, 09:58 PM
DasCheckers's Avatar
DasCheckers
DasCheckers is offline
This one
Summit SUM-CBJJ118 - Summit® Dual Exhaust Systems - summitracing.com
I really need to buy an exhaust for my newly rebuilt motor so I thought this sounds like a great deal.
If you have it, did it bolt right in?
Also, how does it sound?
I'm trying to put it in my '93 F150 5.0 long box.
Thanks!
Old 02-19-2009, 03:36 PM
ghunt's Avatar
ghunt
ghunt is offline
They must have the wrong picture for that...that shows one of their generic "in front of the rear wheels" kits but the notes say it runs down the right side of the frame.
That whole listing is very confusing...because in the kit's contents it says it HAS that universal duals kit in it. I don't really understand.
From the description it just sounds like they stuck their headers with Walker's 2 1/4" header back kit and called it their kit, but now I'm not so sure.
Old 02-19-2009, 07:54 PM
DasCheckers
I guess I'll just order it and find out!
It a combo of the following.
Dynomax Thrush Turbo Muffler http://store.summitracing.com/partde...part=WLK-17713
Dynomax Blackjack Painted Headers http://store.summitracing.com/partde...part=WLK-85054
Dynomax Universal Header Dual Exhaust Kit http://store.summitracing.com/partde...part=WLK-89000
Old 09-27-2009, 11:58 PM
sca91ford's Avatar
sca91ford
sca91ford is offline
seems to be a great deal...
Looking to get the same kit for my 91 5.0, how did it work out for your truck?
Old 09-28-2009, 12:33 AM
97FRD1TN's Avatar
97FRD1TN
97FRD1TN is offline
my buddy put it on his 95 short box.It is junk and you have to cobble it on and does not sound very mean,i think he ran it a whole week and then scrapped it out
Old 10-01-2009, 10:52 PM
DasCheckers
What he said, it sucks.
Took my Dad and I almost 3 hours to cut and weld one side.
Sounds ok, very quiet. Looks like ***, it's a cobbled together kit that is by no means a bolt in.
Sure, it comes with a few flexible pipes but you still have to pie-cut your *** off to get it around everything.
I need to call them and really give them an earful still.
I'm going to go with headers to single 2.5" now.
Old 10-02-2009, 10:37 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
That's what universal means. One size fits none
Your 2.5" single back will be sufficient. True duals that are two different lengths because they both have to run down the same side of the truck would seem to throw the balance off anyway because the back pressure will be different for each side.
I would go headers to a 2.5" Y pipe. 3" from the Y to a 3" inlet Muffler with dual 2.5" outlets and tailpipes. This will give you plenty of flow and both sides of the engine will be balanced.
Kcorrie
09-15-2014 01:43 PM
Cduff
06-03-2014 12:09 PM
ScumbagSteve
01-27-2014 11:57 PM
ryanscott
23
07-03-2013 02:30 AM
wildstang
22
11-26-2009 10:58 AM
Quick Reply: Anybody using the Summit Dual Exhaust kit on a '93ish 5.0?
