Wiring brake light.
Old 02-17-2009, 10:00 PM
TexasDiesel97's Avatar
TexasDiesel97
TexasDiesel97 is offline
I'm glad i could help
Old 02-18-2009, 10:58 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Exclamation
ONLY one question:
Acording to the written by Texas and with the diagram from BlueMule, I thought was the same , BUT are exactly the opposite ; Im confussed now: it can be done in either way, it doesnt matter, or what is the correct?
Old 02-18-2009, 01:25 PM
Hussler's Avatar
Hussler
Hussler is offline
Either way will work .. your call.
85 - 86 is the relay coil.
30 - 87 is the relay contacts.
Old 02-18-2009, 02:00 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
ah, OK, thank you very much.
BTW, searching in the web, I found the module to use when you install a Third brake light. Here are the links, and one of my brake light.
Command Third Brake Light Logic Module
http://www.commandelectronics.com/logicmodule.html
http://www.buyautotruckaccessories.com/product.cfm/cf-bin/pn.pacer-taillight-logic-module/#apps
LED BRAKE LIGHT.
http://www.am-autoparts.com/AM/Tail-Lights/Chevrolet/Suburban/-/AM-18017556/?utm_medium=shoppingengine&utm_source=ShopzillaSF
Old 02-23-2009, 12:08 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Unhappy
UPDATE:
Well this weekend I put the relay and the third brake light worked fine. But after looking at the wire from the third brake light, I found that the wire had a little exposed part of the cooper material in the part between the camper shell and the tail door, so, now I understand why the third brake light shorted and blew the #13 fuse in the dash.
Now, my question is: do I let the relay there (with more connections, with the possibilty to fail)? or I reconnect the third brake light wire to the wire I found that comes on with the brake (only one direct connection)?
Old 02-23-2009, 03:40 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Originally Posted by RÖENTGEEP
UPDATE:
BUMP, BUMP
Old 02-23-2009, 03:49 PM
Hussler's Avatar
Hussler
Hussler is offline
Since you found a short my vote is to reconnect the third brake light wire to the wire you found and give it a try. Less to go wrong.
Old 02-23-2009, 03:53 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
yes, thank you, I was thinking the same thing. I will.
waverous
10-10-2016 10:10 AM
Kitty Chandler Carr
10-02-2016 12:18 PM
REALTREE-F150
05-18-2014 09:44 AM
darinbrooks
12-01-2010 06:23 AM
joeskeeter
1999 to 2016 Super Duty
02-05-2008 06:30 PM
Quick Reply: Wiring brake light.
