LEER Truck Cap
False about Leer and Century being the same. I bought my Leer right at the factory in Milton, Pa. Century comes right out of Indiana state. I have a 08 Lariat with the White sand tri coat and what a pain to match. After dealing with Century caps, they made two caps for my truck, the fit was horrible, horrible, horrible. Even as the dealer, Bigler Boyz in Bigler Pa, has not an ounce of customer service, he was pissed at Century at what they sent.
Then I went to Leer in Milton. Their first paint job was a joke as to color match. Repainted and is close but you can still see some difference. And I even drove to the factory so the paint guys could see my paint. Guess this is a tough color to match. Nothing is perfect.
If Century could do some QA, they actually have a better cap than Leer as their roof is two layers with honey comb sandwiched in between, Leers cap roof is only a single layer.
I just had a Leer cap put on my 2009 F-150 with a 6.5 ' bed. Great paint, horrible fit. It sticks out 9/16" past the bed on the sides. It looks like a Darth Vader helmet sitting on the bed. Both the dealer and the factory said this had to be done to keep from chipping the paint?*? Make sure you see one installed before buying or you could be sorry like me.
I took it back and he adjusted it by sliding it back a little so it no longer rubs, but to do that the had to enlarge the holes he drilled in it. I think I should have ordered the shell with the open front end instead of the built in removable/sliding front end window. My last truck had the open front end with the rubber boot and I had no problem with rain getting in, but these new trucks have channels on the roof that could possibly cause a problem. He said he'd convert it for me if I want. Any advice on that?
2010 F-150: Leer XQ100--Do Not Buy
Do not, I repeat, Do Not Buy the Leer XQ100 for the 2010 Ford F-150 XLT SuperCab. The rear hatch is a straight line at the bottom edge and does not fit against the contour of the tailgate sill, which bows out. The fit, seal and appearance are terrible. I was furious when I saw my installation. I will seek to return the cap for a full refund from Leer. If I am met with any resistance I am filing with the state attorney general's office. I recommend this option to anyone else who has been stung by this poorly-designed product.
I had an ARE on my 95 F150. Great cap. I've had an Eagle cap on my 05 SD and my 06 F150. Great quality. Color match was fantastic. The price was $975 for my 6.5' bed F150. It's their Maverick cap. It's approximately 4" above the cab. A friend of mine just bought one for his 02 SD. It's a cab high short bed for $950. They are made in Plymouth, IN. Leer has a couple of plants in Indiana as well. But I don't like the quality or price. Another friend has a Leer on his 03 SD and he's not that satisfied with it. He has had some quality issues that he's had to live with. The Eagle cap is very strong on top. It's reinforced as well as or better than the ARE I had.
I have a Leer 122 that I bought new last year when I got my 2001 PSD, and the exterior is fine, the interior quality was a little buggered. The front sliding window is all messed up, bent trim rails etc. I only noticed it months after they installed it, can't tell if it was Leer or the shipping/cap joint.....
Exterior quality is decent, no issues so far. I don't have a noticeable overhang, no worse than anything else I've seen.
Not sure if I'd go with Leer again, then again everything else gets mixed reviews as well.
#28
#29
Howdy, Welcome to FTE. I've never owned a Leer cover cause I didn't care for the look. However, I recently put a Jason Hugger cover on my 2010 F150 scab 6 1/2 foot bed and it's fit is perfect and the color match is exact. I wish you the best possible outcome on your experience. Good luck.
#30
I have an ARE DCU topper on my 09 F150, and have extensive experience with the DCU on 01, 03, 07, and 10 F150 SCrews... they are excellent. I would recommend the factory-matched paint (I think it's standard now, actually). Also, see if you can talk them into installing the power locks for you - very handy feature.
All of the above have the double swing-out rear doors.
The 09 and 10 trucks also have a Bedrug under the topper, which is fantastic, and much easier on the knees and **** when in the back of the truck doing work (wiring, primarily).
