1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Bought a `61 F100....BUT
Old 02-09-2009, 08:15 PM
FoMoCoPower's Avatar
FoMoCoPower
FoMoCoPower is offline
Hello,I don`t normally post on here because I`m rarely stumped like I am right now.
I picked up a 1961 F100 unibody today. I assumed that all 2wd F100`s had 9" rears...but this one does not. When I was loading it on the trailer I was very suprized to a Spicer/Dana type rear axle under it. It has the correct 5 on 5.5" bolt pattern,and it looks to be the right width.
Would this be some sort of factory option,or was a 53-56 style rear swapped into my truck at some point in it`s life??
Old 02-09-2009, 08:25 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by FoMoCoPower
Hello,I don't normally post on here because I`m rarely stumped like I am right now.
I picked up a 1961 F100 unibody today. I assumed that all 2wd F100`s had 9" rears...but this one does not. When I was loading it on the trailer I was very suprised to a Spicer/Dana type rear axle under it. It has the correct 5 on 5.5" bolt pattern,and it looks to be the right width.
Would this be some sort of factory option, Right-o! or was a 53-56 style rear swapped into my truck at some point in it`s life??
Welcome to FTE
Your truck has a LIMITED SLIP rear end if it's a Spicer-Dana 44.
When 1959/67 F100's were ordered with Limited Slip, the Spicer-Dana 44 was installed.
And...Ford also offered as an option, the Spicer-Dana 60 for 1961/67 F100's...with or without Limited Slip.
This 60 uses the same 5 lug, 5.50" bolt pattern wheels.
Look on your trucks Warranty Plate for the AXLE code, post what it is.
Old 02-09-2009, 08:41 PM
FoMoCoPower
Axle code is A1
Old 02-09-2009, 10:51 PM
FoMoCoPower
BTW...also stumped on what these two codes mean...DATE: 222 and DSO: blank
What I do know is that it is an original paint Holly Green `61 Unibody shortbed 2wd,with a 223,light-duty 3spd,and it was the 644th unit built in March of 1961,so I am guessing within the first few days. My B-Day is March 4th,would be pretty sweet if this truck was the same...lol.
Old 02-10-2009, 03:59 AM
NumberDummy
Axle code is A1
A1 = Spicer-Dana 44 / 3.73-1 / Limited Slip / 3300 lb. Rear Axle Capacity
The last line on the Warranty Plate should have the GVWR / HP / RPM / DSO code.
There is no date shown on the facsimile of the Warranty Plate in the parts catalog for 1961/62 F100/750's.
Suggest you post a pic of the plate. Ford didn't always stamp the codes in the correct location.
Old 02-10-2009, 07:16 AM
FoMoCoPower
I will check again,but GVWR/HP/RPM are there for sure but no DSO.
Old 02-10-2009, 07:29 AM
Faber's Avatar
Faber
Faber is offline
Mine doesn't either.
Old 02-10-2009, 07:32 AM
Faber's Avatar
Faber
Faber is offline
NEVERMIND......
your right like usual
4th number set, "53" nowhere near the 'DSO' title.....real far to the left.
Old 02-10-2009, 12:09 PM
FoMoCoPower
Checked again,everything is there but the DSO,will take a pic to prove it.
Old 02-13-2009, 10:27 PM
FoMoCoPower
So....no other opinions on the missing DSO or the Date:222???
I checked the tag a dozen times,the bottom row of codes has something for GVW,HP,and RPM,but the DSO is completely blank.
Old 02-14-2009, 10:04 AM
IsoGrifo's Avatar
IsoGrifo
IsoGrifo is offline
date 222
perhaps it isn't march and it's February 22nd? as in 2/22
idk just throwing something out there.
Old 02-14-2009, 05:59 PM
garbz2's Avatar
garbz2
garbz2 is offline
A picture speaks a thousand words.
Garbz
Old 02-15-2009, 11:37 PM
FoMoCoPower
Obviously nobody believes anyone without a picture on here. Guess telling the truth means little nowadays.
Old 02-16-2009, 02:02 AM
Faber's Avatar
Faber
Faber is offline
now, now....just take a pic, click on your name, create a gallery or whatever and upload it....
or, don't....doesn't matter to me....
Old 02-16-2009, 03:10 AM
NumberDummy
Originally Posted by Faber
NEVERMIND......your right like usual
53 = Kansas City Ford District Sales Zone Office, where the original selling dealer ordered the truck from.
FoMoCoPower: It's has nothing to do with what some of us believe..or not.
Do you see what FTE member Faber typed above?
Ford mis-stamped code(s) on the Warranty Plates, put them in the wrong place, or may have left the code(s) off in error.
There's an old saying: "A picture says a 1000 words."
If you lived in Burbank CALIFORNIA, I could swing on by, and look at your Warranty Plate.
Can't do that since you live in Burbank....Illinois.
Quick Reply: Bought a `61 F100....BUT
