56 wiper motor/switch replacement
I was able to get 56 ford truck wiper transmission arms, bellcrank,baseplate and motor for my 56, The motor is toast,rusted beyond repair. I need to replace motor and switch assembly,what could I use from a junkyard that would require minor fabrication to the stock bellcrank? thanks, John
Got thinking some more about this.
This is Cowman's jeep wiper install in his '53 f100, more pictures in his gallery.
53-55 12v. conversion from Sac Vin Ford site;
56-60 12v. conversion from Sac Vin Ford site;
The replacement 56 motor is different then the 53-55 replacement one (originally the 6 to 12 v. change) so not sure if that would make the jeep motor change a problem in your '56 or not as Cowman’s was a ‘53?
I need a favor if you get a minute, for something I was thinking about trying, could you please measure the distance between the two wiper holes/posts? Centre to centre and let me know.
Thanks, Ray.
Thanks, Ray.
Might I suggest you surf over to "Newport Engineering" who makes new aftermarket wiper set ups for F1 and F-100 trucks. I have one on a variable delay switch in my 51 F1 and it is fantastic!
Here's the link:
New Port Engineering - Home of the Clean Wipe Wiper-Drive
Here's the link:
Also..... 1956 Switch and new motor (import?) on eBay item # 170146582023 $ 148.00
Received 4,116 Likes
on
1979-1986 Jeep Cherokee Wagoneer Windshield Wiper Motor Item number: 190283011061 price: US $25.00
1956-60 Ford Truck #NE5660FT The wiper motor is relocated to the inside of the cab, and features a heavy duty, two speed,self parking motor that bolts directly into the stock holes and connects to the stock wiper transmission linkage arms. DONT TRUST A REBUILT MOTOR, UPGRADE TO A NEW PORT WIPER DRIVE.3-year warranty PRICE: $209.95
While you were at Newport did you happen to notice their "Delay" wiper switch? I got one for my Newport set-up and it has "infinate" delay speeds. ALSO though, it will allow you to use a 56 ****!
I did that for mine because the 51 **** has that slot and key "push on" arrangement. The 56 **** uses a set screw. That delay wiper switch at Newport is $75!!!!!!!!
armyaviation
03-25-2017 05:49 PM
Col Flashman
03-08-2017 05:47 PM
56 ford custom
12-01-2013 12:23 AM
