1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
P1506 obd code question
Old 02-07-2009, 09:56 PM
uno's Avatar
uno
uno is offline
After getting p1506 overspeed code. Replaced iac and still have higher than spec idle ( 1100 + - ) and restarted the truck after disconnecting the battery and code is gone but high idle is still about 1100. Anyone have an idea what iam missing checked some of the top side vac hoses and they seem good.
Old 02-09-2009, 07:23 PM
Gevans17's Avatar
Gevans17
Gevans17 is offline
1506
try cleaning your throttle body
Old 02-09-2009, 08:14 PM
alloro's Avatar
alloro
alloro is offline
Received 4,194 Likes on 2,430 Posts
I'd say look a little more for a vacuum leak.
Old 02-12-2009, 09:25 PM
uno's Avatar
uno
uno is offline
i THINK its a vacum leak, hard to hear the spot. replaced the IAC hoping that was it. base idle should be 780 in nuetral. idles at 1100 nuetral,750-800 in gear and lower with air - point me in the right direction pls. ever had the same type problem yourself ?
Old 02-12-2009, 11:34 PM
alloro's Avatar
alloro
alloro is offline
I've had this problem on other vehicles in the past and it was always a vacuum leak.
Old 02-13-2009, 07:06 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Drive it for a few weeks until the MIL comes back on and then re-scan it. The new fault code should give you better guidance.
Steve
Old 02-21-2009, 06:44 PM
uno's Avatar
uno
uno is offline
hey alloro, getting back to you after new IAC and TPS code cleared..........now its back with an idle at 1100 rpm, please help if you know a good spot to check for vac leak.....or ?
Old 02-22-2009, 12:41 PM
alloro's Avatar
alloro
alloro is offline
Did you try disconnecting the battery for 10 minutes to clear out the previous idle parameters?
Old 02-22-2009, 07:57 PM
uno's Avatar
uno
uno is offline
Thumbs up solved
after a new TPS and IAC.......my only problem was the PCV, base idle 600-650, for a whopping $3 ( finacing available with approved credit ) haha
Old 02-22-2009, 09:01 PM
alloro's Avatar
alloro
alloro is offline
Ahh so it was a vacuum leak after all.
Gerryatrics
1997 - 2003 F150
19
03-30-2014 06:11 PM
pleshdog21
1997 - 2003 F150
09-10-2013 06:42 AM
pfpost
1997 - 2003 F150
08-10-2011 01:19 PM
firefighter1416
02-13-2010 05:30 PM
Quick Reply: P1506 obd code question
