Loss of power & missing
Hi Driving home from work the truck started to run rough and no power.I have read up on the uvc problem so when the truck was running I pulled off the passenger side plugs on at a time and there was no difference.There was a difference on the driver side when I did it.I checked the plugs they were not burnt or melted and I took off the valve cover and everything looked fine.Is there something that controls a whole bank of injectors that I am missing thanks
Did you look at the pins for being burnt or melted in the connections?
There is the IDM (injector drive module) that sends the signal to each bank and it could have water inside and it will cause havoc and could shut down entire bank. It is located on the drivers inner fender well and is held on with a few bolts. You could take it off and shake it for water sound
on
$1600!!!!!!??????? I have never heard of one that high!! $575 is still higher than I would pay. Unless your in a real big yank to get the truck (we usually are!) check out auto computer exchange on ebay. Just search IDM and you find them. Great prices and products.
Hi guys I believe I'm having the same problem. It seems that I'm losing the a hole bank. Not sure what side. When disconnecting the harness from UVC connection outside the cover. Do I have the engine running or not? I know it's high voltage so I'm assuming to have engine off and afraid if running it may mess up the PCM. Am I thinking right? I've also been looking for the proper way to firgure out my problem from start to finish.
My check engine light comes on and the truck won't hardly run it won't pull itself on flat ground. Then it clears up. Then shortly later it does it again. And now it's trust staying that way.
I've replaced the CMP, fuel filter, oil and filter. Cleaned the battery cables and have made sure that the batteries are fully charged.
I was going to start with checking the connections at the valve covers and then the ICP and then to the IPR.
But I can't find the proper way to check all of these. I have no scanner but had it checked at Advance Auto but no codes found. It also didn't seem like they knew what they were doing.
I have the regular tools like wrench's and socketts and DVOM but no pressure gauges.
Any info would be great. Oh I have 96 F250 7.3L
Thanks,
Thumper
Thanks,
Thumper
Thanks,
Thumper
Thanks,
Thumper
