Transmission Solenoid body 5r110 torqshift
Old 01-31-2009, 04:08 PM
hacksaw830's Avatar
hacksaw830
hacksaw830 is offline
Hi,
Ive got a bad solenoid body and I have a doner tranny that has a cracked body but aleged good solenoid body, But when I removed the solenoid body, a star shaped washer looking object fell out, its about the size of a nickle and the prongs of the star are folded opposite of each other. Can any of you tranny mechanics help me out with a diagram or tell me where it goes? It looks like it possibly goes into the tranny body, there are three holes two of which have a 12mm nut in them the third does not it just has a couple of holes is this correct or not.
Old 01-31-2009, 06:16 PM
hacksaw830's Avatar
hacksaw830
Nevermind I found out where it goes.
Old 12-31-2014, 08:07 AM
davepaque's Avatar
davepaque
davepaque is offline
The same thing just happened to me. Where does that washer go? Thanks.
Old 02-15-2015, 07:59 AM
gdkerr's Avatar
gdkerr
gdkerr is offline
Coud either of you provide guidance on what the star shape disc is? I have the same problem.
Old 02-15-2015, 05:58 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
That is a flow restrictor. At some point they
switched to a bolt that has an orifice and no
washer thing.
What are you using to align the valve body when you reinstall it?
Sean
SANDDEMON08
6.4L Power Stroke Diesel
12-13-2018 06:51 AM
Howiehighboy
04-12-2017 03:54 PM
Kdawg89
06-17-2016 07:50 PM
BigRedTed
02-22-2016 12:15 PM
94Bronco2215
1978 - 1996 Big Bronco
07-28-2015 07:35 PM
Quick Reply: Transmission Solenoid body 5r110 torqshift
