Mileage Ford F250,1992,7.3 Non turbo!!!
Old 01-29-2009, 05:41 PM
FordF350Superduty's Avatar
FordF350Superduty
FordF350Superduty is offline
Hi guys!Tell me,please,what mileage is Ford F250,1992, Non Turbo Diesel?Thanks.
Old 01-29-2009, 06:11 PM
RCrawler's Avatar
RCrawler
RCrawler is offline
Need to know what transmission, rear end gear ratio, tire size.
I only get 12-13 mpg on mine. But it has 4.10 gears with 35's and is pretty heavy.
Jason
Old 01-29-2009, 07:02 PM
axel 56's Avatar
axel 56
axel 56 is offline
I get around 18 to 20 with 33 in tires and 3.54 gears with e4od auto
Old 01-29-2009, 07:06 PM
84 f250 6.9's Avatar
84 f250 6.9
84 f250 6.9 is offline
Jason
lol missing your prius? check under my tires lmao thats great
Old 01-29-2009, 07:24 PM
joe f350's Avatar
joe f350
joe f350 is offline
i get around 17 empty i have 3.55 gears and 37 loaded u dont want to know
Old 01-29-2009, 08:22 PM
FordF350Superduty
12-13 - bad,but 17-20 sounds very good.I dont know what gear ratio and tire size,looks like regular size,and its automatic transmission.
Old 01-29-2009, 08:29 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Dave Sponaugle is offline
The auto would be an E4OD which would be better for mileage.
IDI fuel mileage depends a lot on how you drive it and where you are located.
Fast starts, lot of hills and driving fast all drop the MPG.
Old 01-29-2009, 08:51 PM
RCrawler's Avatar
RCrawler
RCrawler is offline
You have to consider that mine needs a set of injectors and weighs close to
9K lbs. On the highway, I can get about 15 if I can keep it at 60 mph. I have been putting off changing the injectors, figuring that they will last until an engine swap. I don't drive it much right now, so the fuel mileage doesn't bother me.
Jason
Old 01-29-2009, 10:31 PM
FordF350Superduty
Thanks a lot,guys!!!
Old 01-29-2009, 11:04 PM
Dean88's Avatar
Dean88
Dean88 is offline
I get 12-13, but I got a 4.10 rear end and C6 auto, so no OD. I'm not quite as heavy as some, but with my homemade bumpers, and aerodynamics worse than a brick due to my homemade frontbumper, I'm pretty impressed, especially when I say show me a 460 in my same set up that can break 10 mpg.
Old 01-29-2009, 11:25 PM
joe f350's Avatar
joe f350
joe f350 is offline
maybe a newer one
Old 01-30-2009, 12:27 AM
terrdnf's Avatar
terrdnf
terrdnf is offline
mpg
Hi GANG!! mines getting 19-20 empty if i keep her around 70MPH and that was checked going up and down Cajon pass out here to work I guess if i was running more flat ground it would be up around 20-22 i guess . but i have 4.10,C6, gearvendors OD,ats turbo. and whats a prius?? is that a wheel chock,? have a safe one everybody... glad to be part of the group!!!!
terry the IDIot
Old 01-30-2009, 03:58 AM
LCAM-01XA's Avatar
LCAM-01XA
LCAM-01XA is offline
Well yes, that ATS will help you out big time, especially going uphill.
My truck, 7.3 n/a, dually, 4.10s, E4OD, pump turned up and advanced a bit, it gets 18mpg at 2000 rpms (60 mph) now, used to pull 20 in the summer on long trips. I do a lot of engine braking tho, and I don't let the cruise drive for me unless the road is nice and level. Under similar conditions your F250 should do about the same, if not better cause of the SRW setup and the better aerodynamics.
Old 01-30-2009, 08:31 AM
ghunt's Avatar
ghunt
ghunt is offline
Geez I never do nearly as good as you guys...I've been getting 13 mpg around town...although on #2 diesel this winter I haven't been doing much better than 11 around town. Of course, my stupid intermittently dragging brakes have probably been hurting those numbers too.
Old 01-30-2009, 09:18 AM
Lead_Pusher's Avatar
Lead_Pusher
Lead_Pusher is offline
I'm also getting between 12 and 13 n/a engine with a c6 and 4.10's , and it doesn't matter where I'm driving, but I don't beat on it. I just let it do it's thing.
Quick Reply: Mileage Ford F250,1992,7.3 Non turbo!!!
