Fuel selector valve for SVO setup.
Old 01-24-2009, 06:00 PM
captainradke's Avatar
captainradke
captainradke is offline
I have a 1990 F-350 with a 7.3 IDI motor it did have two fuel tanks, but it no longer does, however the selector valve is still there with the old lines plugged. I want to build a tank for for heating SVO and possibly filtered WMO. My question is can I wire the old selector valve so that I control the return line independently of the supply line. I want to be able to switch back to diesel with out the oil going into my clean tank, so mainly just wondering if this can be done with the stock sector vavle or will I need two valves to achieve this? thanks in advance for any input, this is a great website and has helped me out on numerous occasions.
Old 01-25-2009, 09:38 AM
SkySkiJason's Avatar
SkySkiJason
SkySkiJason is offline
Received 1,891 Likes on 1,142 Posts
AFAIK, the 6way valve switches both at the same time. The plastic Pollak valves are not very reliable anyway - especially if you have adequate heat in your VO system. The 3way hydraforce valves sold by Frybrid are much more durable and can take the heat. Many have tried unsuccessfully to use the stock-type switching valves. Sounds like you've done some good research already. The Frybrid forums are really the best place to post questions about SVO use. Not too much of that kind of traffic here! Good Luck!
Old 01-25-2009, 03:51 PM
captainradke
I had a feeling that would be the case, I'll probably buy something like that then. thanks!
rterril02
11-20-2016 01:12 PM
KHflatbed
10-12-2016 09:58 PM
NicksF250
01-28-2016 05:37 AM
bio-d
05-10-2007 10:03 AM
Pele
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-08-2007 02:37 PM
Quick Reply: Fuel selector valve for SVO setup.
