alternator won't charge
To onefarmer and cOOnhunterjoe. Here's what I got. I bought a meter and tested the following wires. With the truck off and the key off I tested the battery's and got 10.82 volts, with the black on the battery and the red on the large post on the back of the alternator I got 10.58 volts. The 3 wire connector on the top of the alternator the left side wire was a yellow wire and it read 10.58, the middle wire which is the jumper wire back to the alternator read .05 volts and the right side wire which is green read 2.44 volts. I started the truck and was going to do the rest of the test and the truck died and will not start. The batterys seem to be dead again and they are new battery's. I removed the battery's to charge them and I tested them by themselves and they both read 10.25 volts. They are on the charger now. Did I do this right. Remember I have a 1997 f-350 ford dually with a 7.3 diesel
i think i remember the truck, this is the one that has a new alternator that still wont charge?
you need to test the 3 wire connector with it unplugged from the alternator first. with it unplugged the first wire shuold read battery voltage as you said it does already, just double check it. the other outer wire should have 0 volts with the key off, then turn the key on and you should have battery voltage, check that first and get back to me.
I'm concerned about the 10.8v at the battery. It should read a bit over 12v. Maybe the batt was already run down or the meter is off that much. Double check the meter by testing another vehicle.
Thanks screech.owl
88_F0RD
12-06-2016 07:53 AM
scotttahoe
12-10-2015 10:36 AM
harris2108
11-17-2010 05:32 AM
