2009 F-150 tire sizes
Old 01-15-2009, 03:23 PM
RobLenski's Avatar
RobLenski
RobLenski is offline
The two wheel drive XL comes with a p235/70R17 tire standard. Looks like you can get lower profile P255 and P265 tires also. I won't be mud bogging or anything like that, but I'm wondering if the narrower tire is better in snow and rain. Here in Michigan should I get the narrower tire? Would the wider tire tend to "float" on the snow and be more likely to hydroplane in the rain?
Thanks!
Rob
Old 01-15-2009, 04:25 PM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,222 Likes on 804 Posts
In Maine, very rarely do you see an efficient work truck with big tires mounted. The stock size tires are the most efficient for snow. I would actually look for an all terrain tire in the standard size, IMO.
Tim
Old 01-16-2009, 03:44 AM
RobLenski's Avatar
RobLenski
Tim,
Thanks for the info. Makes sense. Same weight, less surface are, more pounds per square inch to cut through the rain and snow, rather than float on it.
Rob
cub102
16
04-08-2015 11:05 PM
96mark8
1999 to 2016 Super Duty
18
09-14-2014 11:41 AM
blueeyedfordguy
1997 - 2003 F150
08-14-2013 10:31 PM
mgraveman
08-07-2013 04:27 AM
BillNYS
15
07-19-2004 09:11 PM
Quick Reply: 2009 F-150 tire sizes
