Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
05 - Escape 3.0 Trouble Code P0354 @#$%
Old 01-13-2009, 12:54 PM
mtbobcat's Avatar
mtbobcat
mtbobcat is offline
I have an 05 Escape 3.0, purchased new, never had a problem, serviced regularly, 45k miles. I had purchased a Code Scout 2500 by Autoxray code reader last year for another car I had so I used it on my Escape because the engine light came on and was running poorly. It came up with a P0354 Ingition coil D primary/Secondary circuit error. After reading many of the postings on here I determined it was the front left coil pack, cyl 4. I swapped the front 3 coils several times and watched the error follow the cyl 4 coil to P0355 and P0356. I purchased a coil from NAPA and replaced it and the spark plug. It made the engine run better but the code just won't clear. I have even put one of the other good coils back in cyl 4 but makes no difference. It is now running rough, poping back through the air intake and maintains only the one same code. I unplug the wire to the coil and it makes no difference. I have even disconnected the battery and moved the new plug to a different cyl. Any help on this would be appreciated.
Old 01-15-2009, 02:41 PM
mtbobcat's Avatar
mtbobcat
mtbobcat is offline
Guess my problem description was a little long for most to read or care. I still have an ignition issue. I can pull the coil wire off of number 4 (D) and no change. Still poping out intake. Does anyone know where the
PCM is located on the 05 Escape or what else might be upstream from the plug and coil that would have this effect?
Old 01-15-2009, 10:07 PM
wptski's Avatar
wptski
wptski is offline
Sounds like you have a problem in the primary coil curcuit, either it's in the harness or the PCM itself is bad.
Old 01-16-2009, 01:59 PM
ericsmith32's Avatar
ericsmith32
ericsmith32 is offline
Sorry but don't much about the codes.. but is the coil you got Motorcraft? I've heard of others having problems with aftermarket coils. Just not on Escapes but other Fords also.
Old 05-03-2009, 10:08 AM
charder's Avatar
charder
charder is offline
My 05 is in for the same issues now. My mechanic tells me that there is a serv. bul. out regarding this issue. There are plugs initially installed that have (or either build up) excessive resistance and that works problems back to the coils and control module. My Escape just died out on the expressway as I gave it a tap on the accelerator- I thought I blew a belt. It started up rough and I was able to limp to work. Coded it out and coils a-f were coming up bad. Cleared that out and just the d coil continues to come up. Took it to my neighbor's shop and its in for a while. He changed the plugs to no avail, and a couple of coils with the same result. He tells me I could be in for a $1k bill if it goes all the way back to the control module. Gotta have it so I gotta do it.
Any chance Ford will help out here? Stop that giggling!
RTrud
07-13-2015 06:37 PM
dyperf
2004 - 2008 F150
11-02-2013 09:18 PM
stuemany
1999 to 2016 Super Duty
02-19-2013 05:34 PM
firemech
12-15-2011 09:25 AM
2003Navi
08-16-2010 12:35 PM
Quick Reply: 05 - Escape 3.0 Trouble Code P0354 @#$%
