'99 7.3 runs rough after warm-up
I have a 99 F350, 7.3 that after warm up the service engine light comes on and truck runs very rough. No codes will come up. It runs fine until warm up.
The truck has 245000 miles on it with no real problems. The cam position sensor has been changed under recall, and of course the high pressure pump hose o-rings.
thanks in advance,
John
thanks in advance,
John
Welcome to FTE. What are you using to pull the codes? The free scans at the parts stores won't read the engine codes in these trucks. Can you describe the rough running a little better? Does it feel like a miss, or like the engine is not firing on all cylinders?
If the CEL (check engine light) comes on, there is a code there. You just need the right kind of code reader to see it. This kind of sounds like a loose UVCH (under valve cover harness) issue. When things heat up, the connection gets worse. If you have an ohm meter handy, read through this thread that has pictures and the test procedure so you understand what you're looking for. https://www.ford-trucks.com/forums/8...ck-shakes.html
Come back and let us know what the test shows.
on
thanks in advance,
John
thanks in advance,
John
99 300k+ stroker
Performance & General Engine Building
05-08-2014 04:18 PM
mclaughlin16846
02-18-2014 02:46 PM
