Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
1992 explorer relay
Old 01-11-2009, 11:43 AM
justin_pistol's Avatar
justin_pistol
justin_pistol is offline
1992 explorer relay
Anyone know what the 2 relays under the fuse panel that is located in the engine compartment go too? The front relay is ticking and I don't know what it is or if it is going to fail soon.
Thanks for any help, Justin
This site so rocks....Thanks agian to the guys for the heater core instuctions for the 97 F-150......U dudes saved me sooooo much time.
Old 01-11-2009, 10:22 PM
mrshorty's Avatar
mrshorty
mrshorty is offline
One will be the EEC relay (that powers the engine management system), the other will be the fuel pump relay. Factory relays are usually black for the EEc relay, and green for the fuel pump relay, but there's no telling what you'll get if they've been replaced. If you look at a wiring diagram to see what color wires go to which relay should allow you to identify which relay is which (the ones in Chiltons are usually adequate for this, and can be obtained for free in the vehicle repair guides at autozone's website if you don't have the print manual).
Old 01-12-2009, 08:52 AM
justin_pistol
Thanks for the info, The relay is still ticking and the truck is still running fine.
I guess I should replace it anyways??????
Thanks agian, Justin
Old 01-12-2009, 09:55 AM
mrshorty's Avatar
mrshorty
mrshorty is offline
Maybe. I expect most people would say to go ahead and replace -- they are inexpensive and easy to change, so you won't be out much if it doesn't fix it.
I might switch the two relays and see if the "ticking" follows the relay or stays with the socket.
Old 01-12-2009, 02:43 PM
marragtop's Avatar
marragtop
marragtop is offline
As Mrshorty said, you should switch the 2 and see if the problem moves. If it does, then I would replace the one that ticks. If either of these relays goes out, you will be in a no start situation.
Justin Jones
11-05-2017 11:15 PM
Justin P
2009 - 2014 F150
04-24-2017 12:07 PM
rockpile
07-26-2016 12:28 AM
036.0stroke
05-06-2016 02:26 AM
TheBlueMule
03-21-2016 08:41 PM
Quick Reply: 1992 explorer relay
