Nebraska Chapter Join Chapter, Leader: 97nukeford
Tool definitions
Old 01-07-2009, 02:30 PM
67nukeford's Avatar
67nukeford
67nukeford is offline
Talking Tool definitions
For those of you that need some help with the proper use of tools....
<TABLE cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD vAlign=top>
[FONT='Verdana','sans-serif']COMMON TOOLS DEFINED
[FONT='Verdana','sans-serif'](TO THE NON-PROFESSIONALS FROM THE PROFESSIONALS - ALL YOU NEED TO KNOW)
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted vertical stabiliser which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh ****...'
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines , refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling 'DAMMIT!' at the top of your lungs. It is also, most often, the next tool that you will need. [/FONT]
[/FONT]
</TD></TR></TBODY></TABLE>
Old 01-07-2009, 02:40 PM
tiny1's Avatar
tiny1
tiny1 is online now
Moderator & CL
That was a good for a few chuckles. I am suprised that there was nothing for the BFH.
Old 01-07-2009, 02:54 PM
67nukeford's Avatar
67nukeford
Well, there is one for a hammer. Just had to give this it's own thread- too funny...and too true in a couple of cases!!LOL!
Old 01-07-2009, 08:06 PM
husker's Avatar
husker
husker is offline
A couple of cases? I could relate to all of them as I think I've done just about all of them at one time or another.
You forgot a couple.
Trouble Lignt: A lighting device that burns out and leaves you in the dark after you have crawled under the vehicle to work. Also useful for burning fore arms and other things.
Crescent wrench. A bolt extraction tool that is useful for slipping and causing broken knuckles and/or creating blood samples.
Surely some of you can come up with some of your own.
Old 01-07-2009, 08:43 PM
fordboy_52's Avatar
fordboy_52
fordboy_52 is offline
alen wrenches: because 100 different sizes are not enough
vice grips, because finding the right wrench takes too much time!
Old 01-07-2009, 10:33 PM
jseim44's Avatar
jseim44
jseim44 is offline
I like it. I may have to print this off for the guys at school and work.....
-Jake
Old 01-08-2009, 10:00 PM
husker's Avatar
husker
husker is offline
Safety glasses or face shield. The safety device you remember is on the work bench after the clump of dried mud and oil falls in your eyes while under the truck.
File. A tool that at one time or another was sharp enough to remove metal to sharpen a tool or make something fit, but no longer useful for much other than poking a hole in the palm of you hand because the handle has long been lost.
mabigredtruck
03-15-2010 06:04 PM
aerocolorado
16
04-13-2009 07:21 PM
77f2504by4
Garage & Workshop
11-07-2008 11:16 PM
e1p1
04-21-2008 04:40 PM
Fomoko1
02-23-2007 08:23 PM
Quick Reply: Tool definitions
