1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
easiest way to pull my 292 engine
Old 01-05-2009, 08:13 PM
spivey1's Avatar
spivey1
spivey1 is offline
I have a 62 4x4 w/292 engine I was trying to fix. But I came across another 292 engine that has only has 70,000 original miles on it for $350. It came out of a 62 unibody runs perfect. What is the easiest fastest way to pull my old motor out? I have pulled out and put in quit a few motors but not on one of these trucks. Someone told me that there was a easy way to pull the front dog house off on these trucks? Or should I just pull the hood off And pull it out that way?
Old 01-05-2009, 08:40 PM
Redmanbob's Avatar
Redmanbob
Redmanbob is offline
https://www.ford-trucks.com/forums/8...p-removal.html takes about 45 min if everything is in decent shape and no rusted up stuff or things breaking. Some help is nice but dont get in a hurry to appease the assistants schedule Good Luck.
Old 01-05-2009, 09:05 PM
spivey1's Avatar
spivey1
spivey1 is offline
Thanks Ill try it.
Old 01-06-2009, 07:27 AM
52 F3's Avatar
52 F3
52 F3 is offline
It is pretty easy to just pull the hood and pull the engine that way. Leave the bellhousing in the truck attached to the trans. There is not too much to unhook and it isn't really much of a job.
Save yourself the problems of rusted and broken bolts and having to align all the front sheet metal again. You will save both time and work.
Old 01-06-2009, 04:45 PM
SJ Bikesaws's Avatar
SJ Bikesaws
SJ Bikesaws is offline
+1
A 292 is a piece of cake to pull, weather you pull it from the trans/bell or the bell/block. Its also an easy motor to rebuild, short of the funky timing chain alignment.
If you pull it from the bell/block you don't have to mess with the rear mounts, just make sure you align the clutch straight before you put it back in.
nice1960f250
02-14-2011 07:49 PM
spivey1
12-24-2008 08:52 AM
doublej80304
10-17-2004 06:10 AM
62galaxie
Engine Swaps
05-23-2004 12:01 AM
idaho211
01-12-2004 01:24 AM
Quick Reply: easiest way to pull my 292 engine
