keyless entry
Old 12-28-2008, 01:34 AM
86paGT's Avatar
86paGT
86paGT is offline
keyless entry
Just took deliveryy of a new 2008 EL XLT…I want to change the keyless entry coda..I have done it before on myt ’04 SuperCrew but cant rebember how……….Theaks in advance...
Old 12-28-2008, 09:04 AM
nckracer's Avatar
nckracer
nckracer is offline
Programming your own personal entry code
To program your own code:
1. Enter the factory set code (keypad will illuminate when pressed).
2. Press the 1 • 2 control within five seconds of Step 1.
3. Enter your personal 5–digit code.
Enter each digit within five seconds
of previous one.
4. After the code is entered, the
locks will cycle, confirming that the
new code has been set.
Do not set a code that includes five of the same number or presents
them in sequential order. Thieves can easily figure out these types of
codes.
Your personal code does not replace the permanent code that your
authorized dealer gave you. You can use either code to unlock your
vehicle. If a second personal code is entered, the module will erase the
first personal code in favor of the new code.
If you wish to erase your personal code, use the following instructions:
1. Enter the factory set code.
2. Press the 1 • 2 control and release.
The system will now only respond to the factory set code.
Old 12-28-2008, 10:40 AM
86paGT's Avatar
86paGT
86paGT is offline
Thanks........Happy New Year
fordguy2236
1997 - 2003 F150
07-13-2013 09:49 PM
ogbobbyjohnson
1997 - 2003 F150
02-11-2012 09:47 PM
61 uni
12-30-2008 08:11 AM
RangerDave78
1983 - 2012 Ranger & B-Series
03-13-2007 02:03 PM
excursion2001
General Automotive Discussion
02-09-2004 10:10 AM
Quick Reply: keyless entry
