New Mexico Chapter Join Chapter, Leader:
Np435
Old 12-24-2008, 04:01 PM
santi2322's Avatar
santi2322
santi2322 is offline
Np435
Anybody here in NM have an NP435 4-speed they want to sell for a 1966 F-100?? Mine is toast and I need to get a new one. If not, anyone know who sells them around Albuquerque besides the junk yards? Thanks a lot.
Old 01-06-2009, 09:46 AM
F0rdFre@K's Avatar
F0rdFre@K
F0rdFre@K is offline
Wish I could help buddy. Only one I came across was for my Early Bronco. Ended up swapping in a C4 instead of the NP435 because I drove that one every day to work. Didn't need the granny gear on a daily driver.
Sold it to my buddy. Rebuilt it and put it in his EB.
I may still have some contacts from the local EB community (I used to run NMEB.net) and see if anyone knows of one locally?
Also, try calling Joe at El Mexicano Truck Salvage. Tell him Eddie sent you. I doubt he has anything that old. But, may be able to point you in the right direction?
Old 01-20-2009, 11:24 PM
santi2322's Avatar
santi2322
Thanks a lot. Any help at this point is very helpful. I can't seem to find one anywhere. I will try El Mexicano. Also, how difficult was it to convert to the C4? I was thinking about going to a C6 but it seems like it is a lot of work. Do you know if a column shifter can be converted to the floor shifter? Thanks again for the help.
Old 01-21-2009, 10:51 AM
F0rdFre@K's Avatar
F0rdFre@K
When I swapped from my 3 speed to my C4, I pulled all the clutch assembly out of my Bronco. Had to disassemble the pedal assembly to get the clutch pedal out. That was probably the most difficult part. But, still fairly easy. Then, the Auto is a plug and play. Only thing to concern yourself with is the shifter. I ran the B&M Mega Shifter on the floor. Came out SWEEEET!!! Has a ratchet shift for quick shifting without over shifting if you like to race.
I have a C4-D20 adapter in my storage. Honestly, it's BEST to find a C4-D20 already assembled (if that's the route you are going). But, if you find your self hunting for parts... let me know...
Old 01-21-2009, 02:18 PM
santi2322's Avatar
santi2322
I called El Mexicano and they didn't know of anybody that would have that tranny and they didn't have one. As far as a plug and play like you said, other people on the forum told me I would need to shorten my axle, get transmission cooling lines, a kickdown linkage, and something else I think. Is that not true or does some of it need to be done? Thanks again for the help.
Old 01-29-2009, 06:33 AM
BChance's Avatar
BChance
BChance is offline
$200 .......................Ford Motor & 4 Speed Transmission
Dunno if it's the right one... but maybe...
ALBUQ F-1
05-05-2013 05:05 PM
BioHazrdMan
45
12-14-2008 10:05 PM
WonderDonkey
31
09-17-2007 10:41 PM
nofd843
2004 - 2008 F150
09-06-2005 11:59 AM
STEVE1103
Arizona Chapter
06-29-2002 03:21 PM
Quick Reply: Np435
