Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
Flex towing
Old 12-20-2008, 11:33 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Flex towing
Has anybody towed with the Flex? I was looking at then on Ford's site and saw that they are capable of pulling 4,500lbs when properly equipped. My folks will be looking for a new vehicle for my mom soon and the Flex would be right up her alley provided that it is good at pulling her pop up trailer.
Old 02-17-2009, 03:35 PM
rambuck's Avatar
rambuck
rambuck is offline
I'd be careful when towing with a crossover, especially the Flex. That is similar to towing with a full-sized car (back when you could as an option). It is not the best idea in the world since they are low to the ground stock. But that depends on the weight of the pop-up. Flex towing is more for a small utility trailer. But when I think about it...it might work. I've seen a couple pics of Flexes towing a small low profile camper.
Old 02-18-2009, 01:47 PM
tcesni's Avatar
tcesni
tcesni is offline
Without knowing the weight of your Mom's pop-up trailer, I would think that it would do a fine job of towing such a camper. Back in the 70's and 80's, my folks towed a 19' camper with full-size sedans that probably weighed less than today's Flex and we went everywhere. I don't see being a cross-over as a disadvantage as long as you stay well within the manufacturer's limits.
Old 04-23-2009, 09:17 AM
Bear River's Avatar
Bear River
Bear River is offline
Former ******
Just keep the trailer balanced and minimize the tongue weight. I would not think the Flex would have any problems. But if you can, keep an eye on transmission temperature.
Old 05-12-2009, 11:45 AM
Headviking's Avatar
Headviking
Headviking is offline
I work at Ford in Oakville Ontario. We assemble the Ford Flex. If you order the tow package it will be fine. It will come with a trans cooler and the hitch is built in with the bumper as well as the electrical harness for your trailer.
Old 05-12-2009, 04:10 PM
tcesni's Avatar
tcesni
tcesni is offline
The tongue weight should equal 10-15% of the weight of the trailer you are towing. This is very important.
Old 10-27-2009, 11:53 PM
B's FX4's Avatar
B's FX4
B's FX4 is offline
ive towed with ours pulling my 2 place snowmobile trailer in a blizzard and it did just fine for being low to the ground.....id say that my set up weighs about 2k +/-
Old 08-23-2010, 07:47 PM
northernsnooker's Avatar
northernsnooker
northernsnooker is offline
Just bought my wife a used 2009 Flex. It does not have the tow package. If I were to add a hitch what would the tow capacity be? 2000 lb?
I do most of my towing with the 150, but it would be nice to be able to tow some small loads (small trailer with motorcycle) on occasion with the Flex.
Old 08-23-2010, 10:16 PM
Headviking's Avatar
Headviking
I wouldn't recommend without adding a trans cooler.
Old 08-30-2010, 12:20 PM
89CrewCab's Avatar
89CrewCab
89CrewCab is offline
This is a great recommedation, but the factory tow package DOES not include an added trans cooler. From Ford's website:
Class III Trailer Tow Package includes a receiver hitch, wiring harness with 4/7 pin connector, engine oil cooler (non-EcoBoost™ engine), and tire mobility kit. Also included is electronic trailer sway control that uses a sensor to detect trailer sway and take corrective measures if necessary.
We are planning to buy a Flex and I typically order whatever vehicle I get with a towing package for the added cooling. However, I don't plan on towing with our Flex since I have an F250. Since the tow package does not come with a trans cooler and it sounds like a "tire mobility kit" = no spare tire, I won't order it.
Old 08-30-2010, 02:55 PM
tcesni's Avatar
tcesni
tcesni is offline
You should have no problem towing small loads with the Flex by adding a hitch. Staying under 2000 lbs. should keep you out of trouble.
Steve Oldenstadt
1978 - 1996 Big Bronco
05-19-2017 04:57 PM
Nicho1197
Fifth Wheel & Gooseneck RV Towing
05-07-2017 11:13 AM
gingerbreadmaniac
01-03-2014 08:34 AM
Craigwell
07-27-2007 10:29 PM
themoonshineboy
General Automotive Discussion
02-16-2006 01:54 PM
Quick Reply: Flex towing
