2001 7.3L F350, Service Engine Soon, truck shakes
#166
I went ahead and replaced the uvc wiring harness, but it didn't fix the problem. I'm pretty sure that the issue is on the passenger side because as it was running rough I unplugged the connector to each side, and when I unplugged the passenger side it didn't change. When I unplugged the drivers side the engine died. I take this to mean that the issue is on the passenger side. But I'm not sure what else to look for at this point, so any suggestions would be great. I checked resistance on all the pins again and they all had good readings. How do I tell if the problem is with one (or more) of the injectors? Or maybe the IDM?
Okay, in looking around on youtube I found a video of what a good and bad injector looks like when running, I looked at mine and only the #3 is spitting oil like it should. #1, 5, and 7 there is no oil coming out at all. Is it possible that all three are bad or is there another likely problem?
#167
Ok, first of all, thanks for all the great info already in this thread. I have a 99 F350 7.3, having the same problem initially described in this thread. It was running fine, suddenly started running extremely rough, no power, and "service engine soon" light came on and stayed on. I did the ohm check described earlier, and the only one that failed was the rearmost injector on the passenger side. But when I pulled the valve cover off, all the connections looked fine, the internal harness connector was fully seated, no evidence of burning or melting, all the wires look good. So what I'm wondering is, could it be that the injector is bad and not the wiring harness? Should I just replace the wiring harness anyway while I've got it apart?
Thanks in advance for the help.
#171
What were the ohm readings you got? Yes it is possible a bad injector causes the IDM to shut down the entire bank. If one injector reading was out of spec, try unplugging both batteries for a while to clear the codes. Unplug the one suspect injector and then start the truck. You'll still get a CEL, but if the truck starts running on 7 cylinders instead of only 4, you've found the problem. Running on 7 cylinders will seem like a very slight miss compared to what you're experiencing with half the engine not running.
#172
I know it's been a couple days, but I got busy with other stuff and haven't had much time to work on the truck. I left the batteries disconnected for a couple hours last night, and when I reconnected everything and went to try and start it up, **** just went haywire. All of the lights and bells were flashing and buzzing and cutting on and off rapidly. When I turn the key to on to warm up the glow plugs this goes on for about 20 seconds, then settles down and things seems to work normally. But when I go to start, as the engine is turning over I hear the electrical system clicking rapidly and see every light on the dash blinking on and off. And of course it won't actually start. So now I'm thinking I have a short somewhere in the electrical system, but I don't even know where to start looking.
If I need to move this to a different thread now just say the word, but the original problem still remains.
#173
#174
#175
Motorcraft ZD-11 which i believe are BERU
Riffraff Diesel: Motorcraft Glowplugs
The reason for not using the autolites is there are reports of the tips swelling and breaking off falling into the cylinder.
#177
Thanks F-350-6
I didn't have any issues with a miss, but....
I was installing HPX, FRx, fuel pressure relief rebuild, plenum inserts, CCV Mod, "Hutch" & "Harpoon" mods, pre-pump filter, Oil cooler rebuild, new water pump.
So I had everything torn down to the point that it was easy enough to pull the valve covers.
Drivers side Ohm ed out the injectors & glow plugs and they were within specs.
Torqued down the rocker arms they were tight already. The injectors, all I can say is WOW I got about a one and a half turns on each.
Added the snipped off quarter to the connector before I buttoned it up.
I'll do the passenger side tomorrow. Looks as if it may be easy enough to unbolt the entire AC mount to gain the additional room to work on the valve cover.
Thanks F-350-6 I never would have thought that the injectors would be so loose.
#178
#179
Most everything is off the front of the motor already, fan, water pump, radiator, intercooler. I'm going to be installing the Fuel Rail Crossover at the same time and removing the AC and bracket will make that chore so much easier.
#180
I did the ohm test from the wiring harness at the IDM and everything checked out as it should, I followed the procedures here:
http://www.gbreman.com/docs/techbull...eplacement.pdf
On test 1, everything read 3.1-3.2 ohms. On tests 2 and 3 everything was open. If I'm reading the tech bulletin correctly, that tells me that all my wiring and the injector solenoids are all good. But is it still possible that one or more injectors are bad? Or is the IDM more likely at this point?
Thanks in advance...
