Are 265-75R15 the same as 31x10.5r15
Old 11-30-2001, 07:07 PM
canadianfordman's Avatar
canadianfordman
canadianfordman is offline
I just picked up a set of chains at a garage sale and on the box it says they fit a 265-75R15, is that the same as the 31x10.5r15 I am running on my F150? Thanks.
Old 11-30-2001, 11:41 PM
shilly's Avatar
shilly
shilly is offline
Maybe you can answer I question I posted in another thread; I've got a 1996 2WD with the stock 235/75R15's on it. Can I use 31x10.5R15's without having to worry about body rubbing or lifting the truck? Thanks, Shilly
Old 12-01-2001, 11:28 AM
wildjon300ci's Avatar
wildjon300ci
wildjon300ci is offline
Yes you can.
Old 12-01-2001, 10:21 PM
canadianfordman
Yeah the only problem I have is when I crank the wheel all the way the tires rub. That could be form the backspacing of the rim, I am not sure. What size rims are you running?
Old 12-02-2001, 08:14 PM
slimersoup's Avatar
slimersoup
slimersoup is offline
Yeah they're the same size. 265 millimeters is section width, the widest part of the tire halfway up the sidewall. 75 means that the sidewall is 75% as tall as the section width. So the sidewall is 75% of 265, or 199 millimeters tall. Two sidewall heights plus the rim height will give you the height of the tire, or 2*199 millimeters + 15 inches. 398 millimeters divided by 25.4 millimeters per inch = 15.65 inches, + 15 inches = 30.65 inches. And 265 / 25.4 = 10.43 inches of section width. So it's a 30.65 x 10.43R15, although due to the undersizing involved in tire sizes it usually ends up identically to a 31x10.50. The wierd part is, since rim size comes into account in the height of a metric sized tire, flotation sizes like 31x10.5R15 and a 31x10.5R16 would be the same height, but a 265/75R16 is an inch taller than a 265/75R15.
Old 12-03-2001, 01:55 PM
canadianfordman
Thanks alot. I finally understand what the metric measurements mean.
Old 12-03-2001, 04:23 PM
gasnparts's Avatar
gasnparts
gasnparts is offline
phoneman91
05-11-2017 01:57 PM
f142f142
06-21-2011 01:08 AM
Trickedout420
03-06-2007 12:29 AM
Dr.Z06
1999 to 2016 Super Duty
02-14-2005 10:17 PM
wgm114
10-11-2002 10:01 PM
Quick Reply: Are 265-75R15 the same as 31x10.5r15
