Shifting into 4 wheel drive
Old 12-06-2008, 10:51 PM
wxscoe's Avatar
wxscoe
wxscoe is offline
I have a 2000 F150 Supercab 5.4L 4x4 auto tranny, with the 4 wheel drive shifter on the floor. All of the manuals I have read for it say this,
"Shifting from 2H (2WD high) to 4H (4WD high)
Move the transfer case lever to 4H
(4WD High) at a stop or any
forward speed up to 88 km/h
(55 mph)".
I've tried shifting into 4 wheel drive with the truck in drive, but stopped, and it just grinded when I tried shifting into 4 wheel drive. I stopped as soon as it started grinding! It shifts into 4 whel drive fine w/ the tranny in nuetral. Has anyone tried shifting into 4 wheel drive on the fly like the manuals say can be done?
Old 12-07-2008, 06:28 AM
jobofly's Avatar
jobofly
jobofly is offline
i do it all the time, im usually not going very fast, maybe 20-30, and it shifts very smmoth. but i have never had a problem like this.
Old 12-07-2008, 08:53 AM
Octane's Avatar
Octane
Octane is offline
Perhaps you need to take your foot off the gas when you shift into 4x4. I know that on mine, it wont go into 4x4 if you have your foot on the gas. Mine has the **** on the dash that shifts it into 4x4 electronically though...
Old 12-08-2008, 12:18 AM
wxscoe's Avatar
wxscoe
wxscoe is offline
jobo, do you have the 4x4 stick on the floor, or the electronic **** on the dash? If you do have the stick on the floor, do you put it in nuetral before shifting to 4 wheel drive?
Octane, I know you can shift into 4 wheel drive on the fly with the electronic 4x4. I have the stick on the floor.
I've never heard of being able to shift on the fly with this before.
Old 12-14-2008, 01:10 AM
bigralso's Avatar
bigralso
bigralso is offline
The only time it might grind is when shifting into 4WD low range on the move.\
To go from 2WD to 4WD high, on the move, you should only have to move the shifter about 1 inch straight down.
Also are all 4 tires the same size??
Old 12-14-2008, 07:04 AM
m350's Avatar
m350
m350 is offline
It will grind if you are spinning the back tires,,,let of the gas,,so all wheels are moving the same speed,,it should go right in,,no grinding.
You must be stopped (well maybe rolling less then 1 mph),,,to go into low Range.
Old 12-14-2008, 08:13 AM
96f150's Avatar
96f150
96f150 is offline
It sounds like maybe your vacuum shift motor(mounted on the front axle tube) may not be slding the front dif into 4 wheel drive all the way. I would have someone move the shift lever between 2H and 4H, while you look underneath and see how far the shift lever on the diff moves. You may have a vacumn leak if thats the case.
Rich
Old 12-15-2008, 11:53 PM
wxscoe's Avatar
wxscoe
wxscoe is offline
big: all four tires are the same size, 265/70R17 Nitto Terra Grapplers
m: I've never tried shifting it while I was moving, so the back tires weren't spinning.
96: thanks for the info, I'll check that out. Like I said in my origianl post, I haven't tried shifting it on the fly, because I didn't think it was possible. I was just wanting to know if anyone's done this before I try it, so I don't jack anything up.
Thanks for all the info. this site is great!
Old 12-17-2008, 10:28 AM
wxscoe's Avatar
wxscoe
wxscoe is offline
hey all. We finally got enough snow that I needed 4wheel drive, so I tried shifting on the fly, and it worked fine. Tanks for all the help.
pbruckne
6.7L Power Stroke Diesel
17
01-05-2020 07:45 AM
FoMoCoFan52
13
04-03-2015 05:16 PM
awq134
2009 - 2014 F150
12-25-2014 01:50 PM
351Cleveland C4
The Next Generation
23
09-23-2013 06:00 PM
Rickx
10-12-2011 06:43 PM
Quick Reply: Shifting into 4 wheel drive
