how to test an egr valve
Old 11-29-2008, 04:57 PM
nickbaize's Avatar
nickbaize
nickbaize is offline
how do i test my egr valve for my 1979 ford f150 351m
Old 11-29-2008, 08:37 PM
Jodell's Avatar
Jodell
Jodell is offline
I have used a hand pump with vac gauge to test mine. You can hook it up to the valve and check to make sure it is opening and that the diaphram is not bad using the pump and making sure the gauge holds vacuum. I will usually put something against the valve diaphram to make sure it moves when the vacuum is applied. I would also imagine that if you engaged the egr at idle you idle should change since you have just diluted the air/fuel mixture. You can also use a T in the vacuum line to the egr valve to check that it is being opened at part throttle with higher RPMs. I am sure people much more qualified than me will answer your question more thuroughly, but hopefully this gives you something to start with.
Old 11-29-2008, 11:50 PM
nickbaize's Avatar
nickbaize
well when i went in to buy a new one because mine wasnt folding vaccum, the ones at auto parts stores didnt hold vaccum ethier on the table so does that mean the ones at the stores are bad or good if they dont hold vaccum off the car
Old 11-30-2008, 12:50 AM
alconk's Avatar
alconk
alconk is offline
If you stick a blunt object under the EGR while the engine is running then push up on the diaphram the engine will most likely run rough or even stall if its working correctly.
Old 11-30-2008, 01:51 AM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
That doesn't tell you whether or not the valve itself is working. You're just manually forcing the EGR valve open to introduce exhaust into the combustion at idle. Yes, the engine will run rough in this case, but it will still do this even if the valve diaphragm is ruptured and the test won't tell you anything.
nickbaize, I'm settling the score on this for good. I went out to the shop, and got out a new, known-good EGR valve. I put a short length of 3/16" vacuum hose on it, and applied vacuum. The spindle moved inward. While still applying vacuum, I pinched off the line and then removed the vacuum source. The valve held vacuum and the spindle stayed in. I let off the line, and the spindle popped back out.
The spindle of a properly working EGR valve will move inward with vacuum applied, and it should hold that vacuum as long as the input port is sealed. That's all folks.
I think this is the third thread you've started on this. Each time I've explained how it should work, and this time I even checked for you myself. If you're not able to repeat my procedure, either the valve(s) are bad or you are checking incorrectly.
Old 11-30-2008, 02:58 AM
alconk's Avatar
alconk
alconk is offline
Thanks for clarifing this.
Old 11-30-2008, 03:33 AM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
No problem
Old 11-30-2008, 10:25 AM
nickbaize's Avatar
nickbaize
ok thanks guys
Old 03-21-2010, 11:26 AM
berry1234's Avatar
berry1234
berry1234 is offline
Does the EGR have to be off the carb to see the spindle move with vacuum applied?
Old 03-21-2010, 11:52 AM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
Depending on the valve, you may be able to see the rod coming off the back of the diaphragm move. If not, it's only two bolts to remove the valve from the spacer plate and look at the actual spindle.
Old 03-21-2010, 01:05 PM
berry1234's Avatar
berry1234
Thanks. I can see behind the EGR looks like the back is open. Vacuum to it didn't move the inner plate and it could hold a steady vacuum. I guess I will take it off and see if it moves.
Old 03-30-2010, 11:15 AM
berry1234's Avatar
berry1234
For anyone with a 78' CA EGR, applying the vacuum to the valve while off the vehicle will not tell you if it works. Had the original and two replacements and neither did anything with vacuum applied. Put them on the vehicle and they worked fine. Revved the warmed up engine to 2000+RPM's and the diaphragm moved as it should. They must need the back pressure to work properly. The instruction sheet that came with the BWD EGR valve also states that a off vehicle test will not show a bad valve. Not sure if this info applies to other year valves.
BrendanFitz
03-05-2017 09:10 PM
Parsedout
04-16-2015 10:46 AM
11jjonn
12-15-2014 05:53 AM
Thorntontribe
11-23-2014 03:30 AM
roller_steve
10-21-2011 07:50 PM
Quick Reply: how to test an egr valve
