Old 11-19-2014, 05:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
Fog Light Bulb Replacement
Old 11-27-2008, 05:06 PM
kjsway's Avatar
kjsway
kjsway is offline
Talking Fog Light Bulb Replacement
I've got a burned out bulb on one of my '07 Expy fog lights. Getting under the truck does seem to yield any obvious way to get at the bulb out from the front or back of the fog light. Are the factory fog lights sealed where you have to replace the whole unit or can you access the bulb? Any tips to remove the bulb or whole unit? Thanks.
Old 11-28-2008, 02:56 PM
chuck s's Avatar
chuck s
chuck s is offline
Page 91 of my '07 Expedition owner's manual:
Replacing foglamp bulbs
1. From underneath the vehicle,
rotate the harness/bulb assembly
counterclockwise, to remove from
the fog lamp assembly.
2. Carefully disconnect the bulb
from the harness assembly via the
two snap clips.
Install the new bulb in reverse
order.
-- Chuck
Old 11-30-2008, 10:58 PM
bjtor's Avatar
bjtor
bjtor is offline
Changed the fog light bulbs on my 08 last month. They were hard to break loose, but I got them turned and it was easy to pop the new bulb in and replace the assembly.
Replaced the stock bulb with the Sylvania Silverstar and they are much brighter.
good luck
Old 12-02-2008, 03:57 PM
kjsway's Avatar
kjsway
kjsway is offline
Thanks for the information on the removal and bulbs.
K.J.
woody367
1999 to 2016 Super Duty
04-26-2017 07:48 AM
kelley350x
2004 - 2008 F150
06-20-2015 07:33 PM
Dogmann
04-12-2014 09:59 AM
billydsr25
Escape & Escape Hybrid
12-26-2012 08:23 PM
ironmine
12-16-2005 06:57 AM
Quick Reply: Fog Light Bulb Replacement
